Hi guy's just wondering about a few bit's relating to the drivetrain of a s2/urs4 (AAN,6 speed box 7a Rear diff and matching driveshaft's etc)
1) Are bolt's from say the donor car chassis similar to those on a Wr (Eg: 4 subframe bolt's off a s2 fit the Wr boltholes?)
2) were is best to get new bolt's and washers etc from. Audi still do them or there a good guide on bolt's needed?
3) what's the best way to set up the 6 speed linkage to a Wr. i have the old 5 speed and a new 6 speed on it's way. What's the best way to modify the 6 speed linkage to fit the Wr.
4) Coilover option's??? using s2 strut's and coilover sleeves ( Top lad Acidburn aka pete)
5) For the AAn rebuild. ill stick new rod's in to future proof. maximum i plan on going is 450 -500bhp and similar torque (long after engine running) what else would you recommend? arp head bolt's,new bearing's (ACL?) or oem?.piston ring's and a block clean. What about standard piston's..i have heard there rated highly. Headgasket etc.
Apologies for some of the daft question's guy's. i will expand on some point's later..am knacked after working 18 hours today so want to pass out.
Many thanks in Advance!!
