Carbon trim Installation....how to?
  • a25c
    • 259
    Have been trawling the net looking for a how to on replacing my wood trim with carbon.The doors should be straight forward enough but the dash pieces I don't know where to start,any tips?
    96 UrS6
    96 UrS6 Avant
    Previous:
    '87 coupe quattro, '85 90 quattro
    '95 S2 Avant '89, 200 quattro 1b
    '00 Allroad 2.7T, '02 S6 V8 Avant
    '96 A6 2.5 TDI quattro Avant.
  • Drummer87
    • Oct 2009
    • 1644
    • Home: United Kingdom Current: Scotland
    Remove the glovebox. Turn on your back head into the footwell. Look up and you'll see six big toothed washers like the doorcard a but easier to remove.
    Pull back tabs/teeth, remove all washers. Then do the reverse to fit new piece. Just make sure to put the teeth back down to have maximum grip
    • shaun5
      • 1610
      If its like mine a ABY coupe you can either remove the glovebox or just flip it down (open it and push the sides in so it folds down further) Look up and you will see 6 clips which you need to remove then swap it over. It depends on age as to what type clips are used.
      • shaun5
        • 1610
        On some of the trims i have seen they have got a spring type clip, much easier to remove than the toothed type you are on about
        • Drummer87
          • Oct 2009
          • 1644
          Yeah my doorcards had toothed and my dash piece had springs
          • a25c
            • 259
            Sorry lads forgot to say it's for an Urs6......
            96 UrS6
            96 UrS6 Avant
            Previous:
            • shaun5
              • 1610
              in that case i cant help you having owned an S6 it looks like a harder job than on an S2
              • quattrostyle
                • Oct 2006
                • 6229
                Still possible, although I can't remember how I got the carbon trim out of an UrS4 I've broken
                • a25c
                  • 259
                  bump...I really want to start this so any info appreciated!
                  96 UrS6
                  96 UrS6 Avant
                  Previous:
