castor
  • A1quattro
    • Jul 2006
    • 789
    castor
    on the rally car we have ur struts and standard steel wish bones with 17mm 2 bolt ball joints, we want more castor but with out spending to much [pref no] money whats the easiest way to get 4.5 castor ,also dont want to mod strut top . are there any direct fit bolt on wish bones / ball joints to fit ur strut
    Rusty's offset topmounts and subframe bushes will get you about 4.0 - 4.5
    For rally use I would bin the pressed wishbone and use forged arms at the bare minimum. Pressed ones are known to snap near the bush
    • A1quattro
      • Jul 2006
      • 789
      nver snapped a pressed wish bone we have seem welded them , plus cast are 500 grams heaver
        I am sure the works tubular wishbones are heavier too. Audisport thought it was a good idea to significantly strengthen them, and add more mass with trailing arms. Are they worth the saving, for such a safety critical item? Just my 2c
        • A1quattro
          • Jul 2006
          • 789
          been rallying the quattro 10 years ,BUT only tarmac , gravel i think you are write . i like the steel wishbones 034 sale and lighter than standard steel units by 500grms , has anyone on here been using them
            If you want some top mounts, then I have a set that I was going to test but rallying would be the ULTIMATE test :mischeif: If they hold up to that, then us road and trackday kids will be fine. I'd have to work out a price though, as the pair have cost me about £400 so far
            The offset subframe mounts need to be tested too, although many have run these in the past without issue. Again, rallying would be a great test.
