Garage / inspection light recommendation
  • AndyP
    • 6049
    I bought one of these recently:-
    http://www.ebay.co.uk/itm/2310062907...%3AMEBIDX%3AIT
    Mainly to use when I'm working under the car, made a small base plate for it so it will sit on the floor and be adjustable
    For the money it's brilliant, only 10W so uses little electricity, runs really cool and throws out loads of really crisp white light. Highly recommended
    I've also got it's big brother, 20W version, bolted to the roof of the garage above where the engine bay sits.
    http://www.ebay.co.uk/itm/10W-20W-30...item43bf4b17f0
    Nice one Andy, I need something like this
    • mdz
      • Jun 2012
      • 775
      • Country: Latvia
      Yep, these are the thing. I'm using two of them. I also made a hook so I can hang it on to the bonnet while working around engine.
      • pasbogdan
        • Sep 2009
        • 1160
        • Country: Romania
        That is a good lamp but i found a major problem with it.When you work in front of it you create shadow and it is useless.
        Bought one and found it is hard to work with.If you put it behind you create shadow.If you put it in front it blinds you.Only way is to aim it to the area you work but it is not as mobile and versatile as the product i attach a pic.
        Sliding,2 magnets one bottom one behind.2 light sources,one big on side and one smaller on top.Strong lamp,resistant to solvents,oil,petrol etc.
        Had 2 of them 3 years i think.Only one gave up the ghost.It was forgot magnet attached to a subframe and the lift crashed it.I bought one with smd? light now.Even better compared to led one.
        The best lamp design.There are hundred's lamps this type but this is the model you need.I tried lots of them.I found the producer.It is not berner as you see in pic.Will look and share info if someone is interested.Here almost all car parts suppliers sell them,you will find it for sure.
        I am not selling lamps,i just love how versatile and resistant it is
        And it has charger also for the lighter in your car
        • Nuvo
          • Nov 2003
          • 3825
          You have my interest.
          • pasbogdan
            • Sep 2009
            • 1160
            • Country: Romania
            Found them:http://www.ringautomotive.co.uk/uk/p...+Lamps/RIL4000
            Maybe you will find another "brand" the same design.But not something else,go for this shape.Trust me.
            The one with led is something about 30 eur and the one with smd? 50 eur.Both of them have same powerfull magnets.
            Regards,
              • 4754
              Very timely,been thinking of buying one of these inspection lamps.
              Found this one by Sealey,it looks exactly like your pictured lamp.
              The Ring one you posted is brighter according to the information but do you like this one as much?
              • Christophski
                • 3632
                I use one like that too Andy. I like the idea of the base plate. Will make one of those instead of balancing it on hammers and things lol.
                • moggies
                  • Apr 2009
                  • 158
                  I have two the same as this http://www.swsni.com/consumables-onl...led-sll6-p1073 not from this site.
                  Well worth the little extra cost very bright.
                  • SteveH
                    • 4460
                    I've had the Ring RIL4000 for a year now and it's faultless. I much prefer the chip on board type LED's to the multiple options. Much brighter light and low power.
                    91 Modded 3B
                    14 A6 Avant Black Edition
                    • SteveH
                      • 4460
                      This is the same lamp as the Ring unit I have, just badged differently. They blind you for a few minutes if you look straight at them
                      91 Modded 3B
                      • moggies
                        • Apr 2009
                        • 158
                        Just had a look, the ones i have are scangrip but will get a ring next time, a bit cheaper.
                        Also have a chip 12volt spotlamp above the garage door, brill. Light chip is the way to go
                          • 4754
                          Great info here to make ones mind up!
                          • Big Lee M
                            • 2571
                            I use one of these, made by ring very bright and has led's on the top so can be used as a torch too.
                            http://www.argos.co.uk/static/Search...8%252F7488.htm
                            Just some finishing touches to do now
                            • terrybullwon
                              • Mar 2006
                              • 8782
                              6ft strip light with guard lay it under the whole car works like a dream!
                              Chef
