Hello fellows,
i have the following issue:
a few weeks ago began:the temperature warning sign was flashing,but the gauge shows only 53 Celsius at the instruments cluster,also in the hidden climate control menu.I checked the cooling level,replaced,and cleaned but nothing has changed.
I checked the temperature sensor.I made a few test with multimeter in cold and warm water.It seemed its working because of changing the value of resistance is cold and warm water.Also i checked the voltage level by the connector its shows the voltage level.So its seems temperature sensor is working correctly but allways shows the same value 53C.
After i replaced the thermostat,load back the coolant .I tried to make the air go out by running the motor without the coolant cap.
But now i have strange noise.I am not sure what it is,the timing belt or the water pump or something else,its similar as a truck noise.
I don't know how to check if the water pump is works correctly.
All tubes are not hard when i pushing
