what size exhaust pipes
  • nip
    • Apr 2006
    • 1786
    • Home: United Kingdom Current: Abu Dhabi
    hi all im having a exhaust made, i was gonna use 3inch pipin all the way down but the silencer boxes are very limited, so it might sound a bit loudish like a dodgy nova , so im gonna use 2.5" this pipe all the way down will still handle approx 350bhp, i can make it as loud as i want or quiet using the sizes of silencer boxes, but i dont know wht size end pipes to use was thinkin of 2, 3inch but afraid it might be 2 big any ideas lads, also removing the cats too. In removing the cats is the power gain noticable
  • s2avant
    • 2426
    My Avant has is 3" from the turbo back (no cats) with 2x3" tailpipes. It can be a bit loud and boomy when it's cold (98dB @ idle from a metre away!!) but it quietens down when it's warm and doesn't sound at all boyracer-ish when on the move. The turbo helps to smooth out exhaust flow though so you don't get that nasty rasping noise you get from novas/corsas etc.
    2 x 3" tailpipes fit perfectly with the recess back bumper so no problems there and removing the cats will make a power gain BUT if your turbo is getting tired you could notice smoke out the back as the back pressure is reduced.
    Ben
    • nip
      • Apr 2006
      • 1786
      cheers s2 avant the exhaust that im havin the middle box is tiny its that small and thin it looks like a motorbike exhaust whats your 1 like mate, i dont want to make the mistake of having a 3" exhaust made and taking it of as its to noisey
      • nip
        • Apr 2006
        • 1786
        sorry forgot this bit s2 avant if u can could u post some pics up of the tailpipes/back of car from about 5 meters away, just wanna see what it looks like cheers matey
        • s2avant
          • 2426
          My exhaust is a Miltek RS2 system which we tweaked to mate it up to the 3" downpipe and cat delete pipe.
          I have only got pics of the downpipe and exhaust from when it was fitted showing the way it was put together and the car is at garage at the moment so it will be a while before I can take some of the tailpipes.
          Ben
          • MidnightBlueS2
            • Jul 2005
            • 1653
            • Home: United States Current: Belgium
            I've got a custom made 3inch turbo-back system with 2 silencers and it isn't loud or boomy.... Only at WOT when the turbo fully boosts will it be a little loud...
            Best of both worlds IMHO.
            Also at 900 Euros, it's a steal !
            Midnight Blue S2 - SOLD - 1993 S2 Avant
            • nip
              • Apr 2006
              • 1786
              ok cheers lads just 1 more question, if i have a 3" system made and a 2,1/2" system made will the performace be the same on both systems
              • terrybullwon
                • Mar 2006
                • 8782
                If your car is running only a remap or standard there will be no differnce in preformance.
                I think the 2.5inch will be ok up to high power ie, 360 or more but the more flow the better from what i have read for high power.
                I will be going 3inch with a tap in there for a wide band egt gauge
                Chef
                • Jon441cc
                  • Dec 2005
                  • 2061
                  Originally posted by Pisobiker
                  - Ø 62mm up to 310 hp;
                  - Ø 66mm up to 360 hp;
                  - Ø 72mm up to 430 hp;
                  - Ø 76mm up to 480 hp;
                  - Ø 85mm up to 600 hp;
                  - Ø 95mm up to 800 hp;
                  Have fun
                  Marco
                  • nip
                    • Apr 2006
                    • 1786
                    yes mr bullwon ive heard that to the guys who makes them is a good friend of mine, also tells me up to 360 2.5" will be ok ,being truthfull i dont think il take it over that, but if i did il build another system out of 3" as its well cheap for me :mischeif: .
                    Cheers ben if u got pics of it bein done that will be great if u could post them cheers matey
