Norwegian Audi 80 2,8 "RS2 sedan"
Have thought about it, espesially since I think about a S2/RS2 engine conversion
It shouldn't be that much work with the battery rear relocation though.Audi 80 2,8 Quattro "RS2"Comment
Whoever does it first must tell and take pics heavily when doing so. I may get to it since im doing a front porsche 6 pot bbk and dive is very heavy some weight from subs would help and I have a huge 110ah battery id love to put in there to power all of my peripherals and components.
-kavon (Mr30psi)Comment
Aha I see!Whoever does it first must tell and take pics heavily when doing so. I may get to it since im doing a front porsche 6 pot bbk and dive is very heavy some weight from subs would help and I have a huge 110ah battery id love to put in there to power all of my peripherals and components.
-kavon (Mr30psi)
I won't do it anytime soon but if I do, I'll be sure to take some pictures!
Who runs power cables UNDERNEATH the car? Never seen it done, and hope i never see it... Take your time and run them under the floormats.Comment
Please hop on over to Audizine B5 guys run it under the car tightly all the time. If you get gasoline spec wire cable its totally fine alot of guys dont want to tear into the interior I personally have always done it through the car because thats just how i do it. But dont be fooled there are alot of stupid people who wouldn't think any better I just wanted to make sure it was being done right. Also in other cars especially newer JDM everything is glued in and fastened very hard to sneakily run a 0 guage wire for a big setup!
-kavon(Mr30psi)Comment
It's been leaking water in the trunk and today I found 3 places where it came from:
1 - The rubber gasket around the trunk opening (where the lid hits)
2 - Behind the cover between the rear fender and the c-pole (?)
3 - Around the lock pin for the fuel cap/lid, which weren't there
So have to order a new rubber gasket around the trunk opening. Thee rest is fixed.
Had to remove everything in the trunk because it was soaking wet today:
Here I used Sikaflex (glue):
Found the gasket which belonged here:
Have started on the aeroport for the sub box. Removed the old speakers and cut out MDF-rings to match the speaker holes. The aeroports will be raised a couple of centimetres to get the length I want inside the sub box. Only the one aeroport is to be used, the other one is just there to make it match
