Speedo / tachometer help needed
  • Tim garwood
    • Jan 2015
    • 17
    Would be v grateful if anybody could help me . I'm looking for a speedo and tacho for a 1991 s2 . Speedo gets stuck then goes haywire tacho is the same. Last to things I need to get it back on road after 10 years.
    Thanks for reading
    TIm, MIght be worth checking solder joints before you buy another unit and also checking the connectors. Have you checked the dials to see if they are peeling too as this can cause issues also
    • Rikki Kitto
      • Feb 2010
      • 6276
      Sounds like bad connections or sensors playing up take them out unplug all connections clean with kontact cleaner see if that helps
      • Tim garwood
        • Jan 2015
        • 17
        Many thanks will try that
