Breaking Audi Coupe Project Car
  • MikeyB571
    • Jan 2011
    • 57
    Originally posted by sidrick
    He means upside down, which they are Like you say, not a problem now though.
    Are the calipers for sale? Are they just standard items?
    Fair enough
    The calipers are standard single piston and I just reconditioned them about 6 months ago with all new seals and I even painted them.
    Yes they are available, say £50 plus postage.
    • MikeyB571
      • Jan 2011
      • 57
      Here are some pics of the sebring back box, i'll take £75 for just the back box.
      And some pics of the rest of the exhaust.
      • Acidburn
        • 13459
        lovely sounding exhaust when I saw the car yesterday mate
        • MikeyB571
          • Jan 2011
          • 57
          Thanks, I just started it up for the last time this morning with the back box off and it was loud. Might have woken the neighbors up
          It's a sad day, she is now really dead. Just drained the last of the fuel out and removed the fuel pressure regulator.
          • MikeyB571
            • Jan 2011
            • 57
            Anyway after I have dried my tears.
            Here are some pics of the fuel pressure regulator, gauge and I also have the adaptor to fit the standard fuel rail so that you can run a remote setup.
            • MikeyB571
              • Jan 2011
              • 57
              And the spit fire lead, they are 7mm twin core and cost a fortune new £50 (new price £170 http://www.larkspeed.com/index.pl?p=35WS93944&a=i)
              • MikeyB571
                • Jan 2011
                • 57
                Here are some pics:
                This is my Jenson Amplifier £40.
                Got a set of clear front indicators £15.
                • MikeyB571
                  • Jan 2011
                  • 57
                  I have got the engine out today and more pictures
                  Clutch is a bit stained from an oil leak but there is no scoring at all:
                  Here are the plastic bits that sit under the headlamps £10:
                  • MikeyB571
                    • Jan 2011
                    • 57
                    I have a few more bits which I never actually got a chance to use on the project as I took a different approach in the end:
                    I have an instrument cluster from an A4 with the ECU and ignition lock and key, reason is that the factory immobilizer is keyed to the ECU/Instrument cluster and key. £40 for the lot.
                    Standard near side headlamp in good condition £30:
                    • Turb4wd
                      • Aug 2010
                      • 12
                      Brake disc
                      Hi do you know size of brake disc and pcd of studs if there are 108 mm please.
                      • MikeyB571
                        • Jan 2011
                        • 57
                        PM sent.
                        • MikeyB571
                          • Jan 2011
                          • 57
                          I have a set of CAT cams that I purchased for my original 12v v6 (ABC) engine, they got very little use as I decided to go in a different direction with the build:
                          Part number is 1003424 specifications can be found here:
                          clearance [cl] 0.00mm 0.00mm
                          duration [0.1mm+cl] 283° 283°
                          duration [1.0mm+cl] 247° 247°
                          valve lift [cl=0] 11.50mm 11.50mm REQUIRED PARTS
                          cam lift - -
                          peak angle 110° 110° followers: O.E.M.
                          timing [1.0mm+cl] 14/53° 54/13° retainers: O.E.M.
                          lift at TDC [cl=0] 2.70mm 2.70mm
                          These cost me £400 and are is perfect condition due to very little use. £100
                          • quattrostyle
                            • Oct 2006
                            • 6229
                            what would be the gain with these on a 2.8?
                            • MikeyB571
                              • Jan 2011
                              • 57
                              I don't have any specific numbers, however there was a significant flow increase on my 2.6, which meant that I had to adjust the fueling significantly.
                              Sorry I can't give any more detail.
                              • MikeyB571
                                • Jan 2011
                                • 57
                                Steering wheel and shocks now sold.
