coming along great love the BIG turbo insane!!! have you decided on a colour for the car yet? keep up the good work and don`t forget to keep the pictures comingbuilding a sportquattro
THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!! -
well, he has mounted the front bumper with the original supports/brackets lately
and he has bought a set Toyo R888 semislick tires, ready to be mounted on the Azev A's
well that's about it AFAIK
Update can be found on:
Unveiling at BMW Netherlands The HPninet has been unveiled by BMW on the bikeshow in Rosmalen. after a small introduction talk the cover was pulled on the bike. It remained 3 days on the show.
Jeffry will fix link on his homepage tomorrow, he doesn't have normal internet access right now, so asked me to update the thread.Comment
- toyo R888 indeed
- not original brackets for the front bumper
- the support for the hatch is a replica from the original
- the bar between the support points for the hatch is original SQ
- the tubing from the strut-towers towards the front, and the rollbar between the top of the strut-towers are also original SQComment
Update
Finally there is some time in my life again to work on the Sport Quattro. In the meantime i've kept sourcing parts and designing parts. Here are some Solidworks drawings i made lately wich are now in fabrication stage.
CheersComment
couple more shots
Thanks Zlobo
Superb work Jeffers!
The drawings of the dry sump and inlet manifold look amazing! One thing about the inlet manifold do you think it will flow well to cylinder number 1? If there was a more open curve into number 1 wouldn't that be better? Or have the inlets being designed with some computer flow program?
Keep up the top work!Comment
the inlet manifold is flowed to some extend in Solidworks.... The plenum design can still vary. I've now used commercially available alloy weld-els to see what can be made with that. The drysump system is going to be like in the drawing. All components are in for the drysump system, except the drive pully. I now found a drive pully wich has enough "flesh" to machine fit it in between the plate and the timing belt cog. The sump pan will be a machined flange, and a alloy sheetmetal cover. So it'll be fairly easy to construct.Comment
