Project 400 Update
  • Ross
    • Aug 2005
    • 3399
    Project 400 Update
    I've been meaning to download a few pics from the camera... here's how things were looking a week ago:
    Out with the old K24... 150,000 miles late, and nearly ready for retirement. And has no shaft play b
  • Ross
    • Aug 2005
    • 3399
    Spot the difference
      Nice RS2 manifold :mischeif:
      • Ross
        • Aug 2005
        • 3399
        Finally managed to get that jammed radiator out! Had to remove a few other major components though...
        • Ross
          • Aug 2005
          • 3399
          you should see the other I have on the way mate. If only I could get hold of some studs for it!!
          I'll get some pics of the engine next - will be installed by then though!
            Whats the problem with the studs?
            • Ross
              • Aug 2005
              • 3399
              RS2 studs are different to the S2 studs aparrently. I overlooked that, and Audi only have 9 in stock (of the required 16). At the moment I don't even have an ETA, so trying to figure out an alternate. More delays...
                Ah thought you knew
                RS2 Parts list from my forum archive:
                Part number Description GBP QTY Total GBP Notes
                N 906 486 01 Ex manifold studs £0.53 16 £8.48
                034 253 031A Manifold £421.52 1 £421.52
                034 129 589A Ex manifold to head gasket £31.33 1 £31.33
                046 145 749 Turbo to manifold nut £0.73 4 £2.92
                N 902 002 01 Ex man. To head nuts £0.64 16 £10.24
                N 902 002 01 Wastegate to manifold nuts £0.59 4 £2.36
                035 129 589D Turbo to manifold gasket £9.10 1 £9.10
                035 145 773D Top oil pipe gasket £0.66 1 £0.66
                035 145 757D Lower oil pipe gasket £0.74 1 £0.74
                N 013 8128 Lower water pipe seal £0.08 1 £0.08
                N 013 8149 Upper water pipe seal £0.05 1 £0.05
                857 253 115 Flexi pipe gaskets £7.94 2 £15.88
                N 902 002 01 Wastegate to flexi nut £0.64 3 £1.92
                N 900 850 01 Flexi to D/P nuts £0.14 3 £0.42
                N 010 24416 Flexi to D/P bolts £0.23 3 £0.69
                447 253 115 Turbo to D/P gasket £3.76 1 £3.76
                N 903 690 01 Turbo to D/P nuts £1.03 3 £3.09
                N 900 730 01 Lower turbo to D/P nut £1.37 1 £1.37
                You can cut down the S2 studs although it's not ideal, it's a listed mod on the forum by Doug_RS2 somewhere........
                • mcandmar
                  • Apr 2004
                  • 5118
                  Isnt it just the two middle studs on the bottom row that need to be shorter
                  91CQ20v - Gone to a new home
                  93UR-S4 - The Magic Carpet
                  94S2Bus - The Emerald Express
                  • Keeper of The Kitten
                    • Dec 2003
                    • 2317
                    The studs from the head to the exhaust manifold are the longer ones?
                    I ask because I am doing exactly the same thing! I think I might be ok though because I have an engine which was already using RS2 EM.
                    I'll have to get some Kitty pics on here I think!
                    __MDC__
                    Martin Cutting
                      • Dec 2003
                      • 2317
                      BTW thanks for that parts list Jamo, nice one!
                      __MDC__
                      Martin Cutting
                        __MDC__
                        Yes they are the RS2 are shorter, i'll post the pics in a sec
                          • Dec 2003
                          • 2317
                          Cool beans!
                          __MDC__
                          Martin Cutting
                            S2 Studs 35mm
                              RS2 studs 27mm
