Audi S2 Coupe Rebuild "Silver Spiken"
  • PeteUr
    • Jan 2010
    • 331
    • Country: Togo
    #256
    Can you get some pictures of the rad/fan setup if you don't mind as i'd like to do this on a project but no-one has been able to supply some really decent pictures. Was it hard to do and did you have to cut/fab anything?
    Loving the project
    Sapphire cos running custom 2.8litre conversion,es cos rims,raven black leather interior and 500+ with the gas turned off.
    Audi s2 cooking on gas
    • Eriksson
      • Jul 2004
      • 329
      Hi..
      I fabricated the lower monting bracket and also the upper.
      Fan holder and the wiring.
      Replaced my radiator for a new one.
      Audi S2 Coupe - 92
      Koni + H&R. PowerFlex bushes. 3" Exhaust
      RS2 IC. RS2 TURBO. RS2 EX MAINFOLD
      Best ET 2006 13.8 @ 157 Km/h (Stock turbo and EX mainfold)
      Best ET 2007 12.78 402m, 0-62mph: 4.2 sec, Speed: 175 km/h (GTEC)(1.1bar)
      Best ET 2007 201m 8.15@140km/h
      Best ET 2008 402m 12.34@177km/h
      My Project
      http://www.s2forum.com/forum/showthread.php?t=16997
      • PeteUr
        • Jan 2010
        • 331
        • Country: Togo
        #258
        Thankyou for the pictures, do you have any pictures of the brackets you fabbed or did you mean the one's for the fan
        • Eriksson
          • Jul 2004
          • 329
          The ones for the fan you can see on the pictures.
          I can take picture nextweek on the other brackets.
          Audi S2 Coupe - 92
          My Project
          • PeteUr
            • Jan 2010
            • 331
            • Country: Togo
            #260
            Thankyou mate
            • andy10v
              • 5996
              Nice project, I like the aan intake manifold install.
              Sold ABY-stock
              • prosty
                • Jun 2005
                • 1114
                The IM did a great deal with intake temps, the intake is now much much cooler than the stock unit, and about 2 meters less piping needed. Much more direct flow. Pelle has done a good job with this.
                2004 9-5 aero
                2009 Subaru Legacy Diesel
                1994 Toyota Supra Eurospec 6-spd LHD
                3-4 Audis in parts
                • Eriksson
                  • Jul 2004
                  • 329
                  Since my Pressure plate failed i removed the gearbox and driveshafts for some new grease and paint. i have also removed the oilcooler and some other stuff.
                  And im messuring for the new turbo oil/water lines. Also new place for a bigger oilcooler.
                  Test Fitted new Ex manifold
                  Replaced the T3 Flange with KKK Flange
                  Audi S2 Coupe - 92
                  My Project
                  • Eriksson
                    • Jul 2004
                    • 329
                    Some more progress made in the garage since my pressure plate failed.
                    Driveshafts painted and new greese.
                    i use the wonderful POR15 paint
                    Gearbox linkage removed, since it was a bit rusty i decided to try rust removal with electrolysis, batterycharger, scrap metal, carbonoxide + water
                    The linkage is getting new stiffer rubber bushings inside the U joint, to get rid of any slack.
                    Watch the magic!
                    The water gets a bit dirty after a while
                    Flywheel has been planed for a nice strait surface
                    New Bearing + pins
                    Audi S2 Coupe - 92
                    My Project
                    • Eriksson
                      • Jul 2004
                      • 329
                      fitted the new oilcooler
                      mounted the wg flange
                      New place for the turbo and WG
                      Audi S2 Coupe - 92
                      My Project
                      • Eriksson
                        • Jul 2004
                        • 329
                        EX Manifold is done
                        42mm tubing.
                        Made by Robert Ajden.
                        Ajdén, ajdén, Ajden, ajden, NMMK, nmmk, Nordisk Morris Minor Klubb Jämtland, Nordisk Morris Minor Klubb, Morris, morris, morris minor, Morris Minor, Traveller, Cabriolet, JÄMTMINOR, JÄMT-MINOR, NMMK Jämtland, NMMKs SOMMARTRÄFF, sommarträffen, engleska bilar, austin, Austin, Sundsvall, veteranbilar, veteran bilar, Pick-up, Morris Pick-up, Morris Traveller. Woody, van, VAN, pickup, PICKUP, turbo, intercooler, hk, wastegate, dumpventil, bypass, böjj, krök, insug, avgas, race, racing, cosworth, celica, bensin, pump, regulator, tryck, laddtryck,trimning, trimma, vw, volkswagen, ford, laddluft, kylare, spridare, boost,
control, styrning, effekt, insprutning, Fiat, 124, Fiat 124, Lancia, renovering, ombyggnad, dekaltrimning, Ajdéns Garage, Austin, Healey, Sprite, Austin Healey, Healey Sprite, Austinhealey sprite, MIM, Mim Juventus, Porsche, gokart, sandloppa, sandrail, BMW, turbokonvetering, bmw turbo
                        Audi S2 Coupe - 92
                        My Project
                        • maniac
                          • 119
                          That ex manifold looks awesome! And so does the new turbo of yours :mischeif:
                          S2 Avant -95
                          • 20vQC
                            • Aug 2007
                            • 684
                            • Current: Italy
                            #268
                            great car! great engine! great evereything! are you still using the 3b ignition setup (distributor)?
                            - Looking for a S2
                            • Eriksson
                              • Jul 2004
                              • 329
                              Yes, im using stock distributor + Magnacore KV85 leads.
                              Audi S2 Coupe - 92
                              My Project
                              • 20vQC
                                • Aug 2007
                                • 684
                                • Current: Italy
                                #270
                                great! I hope to follow your step soon on a near future s2-3b cheers mate!!
                                - Looking for a S2
