Attack of the foamy oil - Part III
  • archiboy24
    • Sep 2003
    • 286
    As of this weekend I am still perplexed by the foamy oil problem. Here's what I tried:
    Pulled the oil pan again and removed the S4 windage tray altogether. Reinstalled stock 3B baffle. Removed the oil pick-up tube and packed the oil pump with white assembly grease - as per George Baxter's suggestion - thinking that the oil system hasn't been properly primed yet. Reinstalled pick-up with new gasket and lock plate, and reinstalled the pan. Filled oil again and removed spark plugs. Cranked starter for a couple of 15 second durations to prime the oil pump. I was amazed at how easily the engine tuns without compression, and nearly silent too! I had to get someone to confirm that the engine was actually turning! Interestingly, as I was cranking I kept an eye on the analog oil pressure gauge. During the 15 second crank the gauge would rise to just over 2 bar. Once it reached about 1.8 bar, the oil pressure warning in the Autocheck came on, leading me to suspect that the 1.8 bar pressure sender is faulty. I don't think I have an oil pressure problem. The other interesting and puzzling thing is that after the priming session I checked the oil to see if it was frothy, but it wasn't. It looked totally normal. I had my hopes up! However after installing the plugs again, I started it and let it run for about a minute. Oil pressure gauge showed 5 bar, but the warning still came on almost immediately. Shut it down and checked the oil and it again was frothy! At this point I'm more concerned with the foaming oil than with the pressure warning. The gauge reads OK and I don't hear any lifter ticking. The engine sounds and runs great. I'm going to replace the 1.8 bar sensor next time I'm there. It could be that it is stuck in the open (default) position after having sat for a couple of years. For the life of me though, I cannot figure out this foaming oil problem! This has held me up for about a month now. I realize I've probably gleaned all the info I'm going to get out of this group and others, but if anyone has some sort of wild brainstorm, I'd love to hear it!
    Regards,
    Ben
    Ben
    Calgary, Alberta
    Canada
    1991 CQ e//S2 w/ RS2 spec 3B 20vt
    Panther Black Metallic
    www.moda-architecture.ca
  • A6 AVANT
    • Nov 2003
    • 321
    Have you given the car any revs? or just let it tick over? Has this problem been there from the start?
    PM me with all the details/scenario etc. and I will ask my mates at work and other mechanics who come in for MOT's for any other ideas.
    HTH
    Regards,
    Chris
    A6 Avant Tdi 110 because as the fuel prices keep going up I am so happy to be getting 649.8 miles to a tank of diesel!! (£50)
    • porkkis
      • 1994
      If I were you I would next check the oil pressure relief valve that sits in the oil pump below temp sensor.
      Try different brand oil also.
      Would it be possible to you yo take some pics of the foamy oil that we'd know what it looks like.
      I would also try to run the engine for a while if the pressure gauge shows no problems.
      • archiboy24
        • Sep 2003
        • 286
        That's a good suggestion. I'll try those things!
        Ben
        Calgary, Alberta
        Canada
