Power Steering high pressure hose removal trouble
  • nribs
    • Aug 2015
    • 91
    I'm struggling a bit to remove the rack end connection which you access from underneath the driver (LHD) footwell. There is a rubber boot you unclip which exposes the rack and the 19mm nut. As is typical space is sparse. Between the steering column and brake peddle there is almost no room.
    Any one go through this when replacing this line? I am debating cutting the line so I can fit box end or socket over it although if I still can't get it then I'm really in trouble...
    Do you have some pictures of where you are trying to get to as it may help others give some advice?
