94 2.6 V6 Manual Quattro Avant restoration project
Huge effort put in and refreshing to see a V6 getting the love it deserves. I have owned a 2.6 fwd avant for 22 years and have looked at what's possible, i think you'll get at least 20bhp extra port matching if you follow the recommendations on 12V.org ( i think it is) which will make all the difference and being quattro you'll need it. Great job.
Thanks, its a lovely lazy engine, plenty of torque low down and sounds fab when you get a good set of twisties and get to take it up the rev range a bit. Definitely going to do the injector port matching over the winter, toying with doing the 2.8 inlet conversion as well if i can find a second hand one at the right price! An extra 20bhp would be lovely!
Time waits for no man. Unless that man is Chuck Norris.
This seconds VdT's remarks above, it is encouraging to see someone recognizing the value in such a project. Although 12V.org may be less now than what it once was, there is still much of that which is still most useful, out there; for the determined to employ. For instance...
Even before port-matching I/M swaps and more (this is a deserving motor), one can address the basics of the known crankcase vent (CCV) sludge, oil consumption, engine vacuum, ignition and fuel metering issues which make for some of the engines as found (predictably, decades on) "laziness".
If not seen already , here is some CCV hose reading and link to the Cam Cover Vent Stand-pipe mod:
12v V6 Discussion - Tour (II) Through a Modest (& Mostly OEM) Intake System; Intro... - https://cimg9.ibsrv.net/gimg/www.audiworld.com-vbulletin/688x646/picture_php_pictureid_193596_432a61afe932010c5fa29c760f073ee5c9e2acaa.jpg tubular_bells.jpg ...the effective (w)hole is greater than the $um of its' parts. Intro &...
The above and more can be found via this forum's thread:
Lago Blue I've been down the 12v.org & audiworld forum rabbit holes a few times now, the level of knowledge from yourself and the others is priceless in the quest to get the best out of these engines!
I've a set of rocker gaskets there, so might do the stand pipe mod next
Not been on this forum for some time, I ran a similar 2.6 'L' reg 80 avant quattro between 2013 and 2016, similar mileage to yours, lovely smooth engine, slighty down on power compared to the 2.8 but feels more refined, however one thing you need to check is the plastic inlet manifold. Its easy to split it into its 2 component halves and once inside you may find the same problem I had with mine.
There is a large rectangular piece of plastic inside that appears to be there to limit airflow and some flaps which are supposed to direct airflow into the manifold, however on mine most of the flaps had parted company and were actually blocking parts of the intake paths. Once I'd removed these flaps and left out the plastic restrictor from the inside of the manifold I discovered several more HP.
Its certainley worth a coupe of hours time to take a look. Nice to see someone else keeping one of these on the road keep up the good work. I wonder where L51MNV is now !
