at this point (money, time, effort) a modern booster would be a great upgrade
Alex, the owner of Ultra is a well known member here on the forum
Our tandem brake booster conversion kit allows you to fit a modern and much more powerful tandem (dual stage) brake booster to your UR quattro or other B2 platform car. Our kit includesServo adapter bracket machined from 6082 T6 & hard anodised to 40μmExtended pedal clevis machined from 34CrNiMo6 / 4340 / EN24T & zinc di-chromated for corrosion resistanceHigh tensile booster fixingsM12x1 SAE brake line fittings for 4.75mm / 3/16 (standard size) brake linesBrake fluid reservoir level sensor connector & terminalsFixings In addition you will need:A suitable tandem booster, master cylinder and reservoir. We supply new TRW (OEM) parts to complete this conversion.Suitable factory boosters can be taken from the following model platforms: B6, B7, B8, C6, C5 RS6, C6, C7, D3.Please note that there a HUGE number of different variants aross various markets and territories; it is not possible for us to provide fitment confirmation of every combination - therefore we strongly recommend choosing componets from the C6 A6 platform due to availability, low cost and gauranteed compatiblity across all territories.It is important to take the booster & master cylinder from the same model variant - mix & match combinations of components is not advise as not all are compatible. Special information for RHD UR quattro ModelsWe have a speciic kit to fit right hand drive UR quattro models: RHD UR quattro Tandem Brake Booster Converion Kit
TRW (OEM) 26.99mm master cylinder to suit our tandem booster conversion, as fitted to many contemporary high performance Audis such as the RS4 & RS6.We recommend this larger master cylinder if you have big brakes with a piston area significantly larger than standard. This larger master cylinder diameter moves more fluid per stroke and will restore a short pedal travel and firm pedal feel.Supplied with reservoir seals and main booster face seal.
Why is all the good stuff always in the UK or Europe.....
