On a positive note, I finally found a great painter near by and have reserved a spot for body/paint. Most painters are a year out here in TN. Most body paint shops only do insurance work now a days, so happy to have found a shop.
Hopefully, the car gets dropped off by end of Oct.
83 Ur Quattro 20v build
Purchased all the hoses and fittings to make up the AC lines. I have had a hard time trying to figure out the AC hi/low pressure switches, which are very hard to find and decided to reached out to a AC component shop, they suggested a binary switch, which has hi/low with in. My issue now is trying to figure out the wiring, its a brutal process and I am ready to turn over to a professional.
Attached Files- 9EE2C514-3B02-423D-8836-FA9B794E6C1E_1_105_c.jpeg (269.2 KB, 225 views)
Started working on the climate control (AC / Heat), made a mount for the AC dryer. Location behind headlight makes for a short run from condenser and is out of the way with easy access. Aluminum mount has thread inserts too make mounting easy.
Pete has finished the digital cluster refurbishments and they are on their way back to me....the clusters look awesome in the photo sent, very excited to get them. Big Thank You to Pete and those who made the recommendation.
Made a aluminum grill for the cutouts in the bumper.Attached Files- D2CAEE5E-37B3-4064-9D77-9A219ABF7807_1_105_c.jpeg (332.8 KB, 114 views)
Made a skid / protection plate for the oil pan and accessories. Sadly, the exhaust down pipe sits lower than everything else, so it will be the sacrificial lamb if I hit something. I welded (4) tabs with nuts welded on back side to mount aluminum, removal is fast and easy. I haven't decided if I want a hole for the oil drain plug.Attached Files- IMG_6904.jpeg (3.47 MB, 131 views)
Sick build
...I like your "custom" way of making this car. I am doing something similar on my Coupe.
Car is on the move and loaded to go to get alignment
Instead of doing the (6) hella lights on the front, I decided to merge old with new and mounted a pair of P6 Pro Baja Design lights. The lights have a amber backlight that comes on with parking lights and hi beam/low beam. I used the additional cross bar I made to mount the lights too. I chased the wire loom through the passenger chassis rail, so minimal harness is seen.
Attached Files- 08423ED1-D7E6-4814-9B17-9F75DF36AC9B_1_105_c.jpeg (281.6 KB, 178 views)
Added a (6) relay / fuse water proof box. I made a mount and used thread inserts for both the mount to body and box to mount. I try and think ahead as to be able to access things easily once the car is fully assembled. The relays will be for the electric seats, seat heaters and the (2) sets of Baja Design lights. I still have to add the power distribution block, ground block and ignition trigger block.
Attached Files- 7E89EEBA-0CF7-4CDF-91D3-2BBFA7C03A1E_1_105_c.jpeg (180.2 KB, 205 views)
great progress
