OK, it's been a little over a month. Some has happened but not much -- I figured I would upload some pics of what's been going on recently; I was too lazy to include pics with the last update.
Pushed the car outside to clean up the engine bay.
Drove from Atlanta to Buffalo and back (for you Europeans, I looked it up and that's like driving from London to Barcelona) to pick up some parts. S2 rear bumper, RS2 ABS front bumper, RS2 fog lights, and 4 Cabriolet door panels from which I can make 2 nice ones. Not pictured, but I also found someone semi-local with a complete black coupe rear seat, black center console, etc.
Stripped out more of the interior to make it easy to run battery cables -- I'm swapping to black anyway so might as well. Most of the random hard-to-find plastic bits will be dyed black. Living somewhere extremely far from most old Audis means I can't just find black ones
A buddy of mine had this Momo/Hella wheel in his 4000 and he wanted something with more of a "race" look, so I traded him the Sparco wheel pictured in the beginning of the thread for it. Obviously premature to put it in but couldn't help it.
Red spray paint from the hardware store is kind of close to tornado so I used it on the area where the battery box was after smoothing it flat. Ironically the color is an EXACT match for the red color that the outside of the car is wrapped in.
Spent some time making sense of the wiring, trimming unneeded wires from the 7A harness, and labeling what needs to connect to what.
Ran into an issue with my cylinder head. I guess it was a 7A head at one point and had holes drilled for a weird brazed water manifold with smaller outlets. When I went to install the 3B water manifold, the holes were too small. It is currently back at the machine shop getting this fixed.
Most recently, I spent Sunday working on the battery relocation. I know this is a simple task but for some reason it was intimidating to me. I am using a small AGM battery, 310CCA. 5x7" footprint so will fit nicely just about anywhere. I'm running a 150A breaker mounted to the sheet metal below the right tail light, and then using one of the large stock studs in that area where the frame bolts to it as a ground, cleaned up of course.
Here is the battery (ignore the terminals, waiting on adapters to typical post style)
I removed the procon10 cable and am running the power cable through the old guides for the procon10 cable. From there it goes into the quarter panel and comes out in the hatch.
Progress has been a little slow because I dug this 1995 S6 out of a yard where it had been sitting for a decade and have been working on getting it back on the road.
