I'm Bored… but I have an '89 Audi Coupe Quattro 20V and a factory manual
  • pscouto
    replied
    Originally posted by John.
    Thermostat fitted the right way ??...... just a thought?
    Running the engine to operating temperature with the expansion tank cap OFF should be enough to expel air if there's any.
    As you're not sure about the reliability of the gauge can you use an infra red thermometer to check ??.....this would also be useful for detecting hot spots and checking coolant flow.
    BTW removing thermostat completely isn't good, jamming it open is better.
    I admire your perseverance
    At this point I don’t even know anymore...
    I threw in a pic of the thermostat for reference.
    I’m planning to grab an infrared thermometer, like you said, to try and figure out what’s going on, but I wanna make sure I actually use it right. My plan is to scan different spots on the engine and radiator to look for cold spots or anything weird.
    But here’s the thing, where’s the best place to really controll how the temp is rising, before reaching a damaging point? Should I be focusing on the block or the head?
    I’m thinking the head, since it’s more sensitive and likely to get damaged if things go south, but I’m not 100% sure.
    Any tips?
  • John.
    replied
  • pscouto
    replied
    Hi everyone,
    After making some good progress with the timing and distributor (finally got the car to start!), I’ve now hit a bit of a halt. The engine runs, but I’m facing a cooling issue, the fan doesn’t kick in, and the car starts heating up fairly quickly.
    At first, I suspected air in the system. I used a vacuum tool attached to my compressor, and although I was able to create vacuum and pull all the coolant into the expansion tank, there was still a cold area in the bottom part of the radiator. That suggested air might still be trapped somewhere or the thermostat didint open.
    To avoid trusting just the vacuum that my compressor makes, even knowing that the coolant rises until the min mark in the expansion tank, i also try this method how-to post on bleeding the S2 coolant system.
    I boiled the thermostat and confirmed it opens. I also rotated it to make sure the arrow (it’s a Mahle unit) points up. Still no luck. Rotate to the right- No luck.
    Then I removed the thermostat completely, with it out, the lower radiator hose finally got hot which is also strange why the thermostat didn’t open, so coolant flow seems okay, but the fan still didn’t run.
    I checked the water pump and it’s in the correct position and is brand new.
    Here’s what else I’ve checked:
    • Jumped the fan connector — the fan started working in full speed.
    • Turned on the A/C — the fan spun up as expected in low speed.
    • Tested the thermoswitch (new unit) by placing its tip in boiling water while the wires were connected and the car running — no response.
    • Swapped in a new relay — no change.
    • The radiator is brand new.
    • The heater matrix/core is not clogged — I verified by testing with a smoke machine and water hose through different inputs, and everything flowed clearly.
    • The after-run fan does kick in sometimes, but not consistently.
    • The 30A fuse is fine — but I’m not sure if there are any other fuses or relays I should be checking in relation to the fan circuit.
    At this point, I’m starting to get concerned about continuing with trial and error. The temp gauge is super slow to respond, and I’ve had to shut the engine off and wait for the needle to rise just to avoid overheating. I have a new temp gauge on the way from Audi Tradition, hoping that will help bring some clarity.
    Appreciate any thoughts or guidance.
    replied
    If the timing marks are slightly out, the engine won't start. Remember that crank pulley rotates twice for each single turn of the cam pulley.
    Changing the timing belt without removing the bottom crank pulley is difficult, even for an experienced mechanic.
  • pscouto
    replied
    Hello everyone,
    It's not starting up! I need your help.
    The first thing I checked was the timing.
    When I originally set the timing, I aligned the mark on the flywheel with the edge of the timing window, installed the belt, rotated the water pump to tension the belt, and then torqued the bolts. I held the crankshaft in position using a ratchet wrench braced against the bracket with the rubber stop. After everything was tightened, I rechecked the marks and they were perfectly aligned — the flywheel mark was flush with the edge of the window. Is this the correct procedure?
    Since the engine wouldn't start, I manually rotated the crankshaft until the mark on the camshaft sprocket lined up with the triangle on the valve cover. Then I checked the flywheel mark through the window and noticed that it was no longer aligned like it was when I originally set the timing.
    So, I redid the timing, reset everything, manually rotated the crank to TDC, and checked again. But after rotating the engine by hand and returning to TDC, I saw that the flywheel mark had shifted again!
    What am I doing wrong here? Is there something I'm missing in the timing procedure? Also, how can I be sure I haven't made the classic 180º mistake? I know that the head had the cams pointing up at and the O marks where in line with the edge of the head before putting it in the block. And i was looking to the first cylinder so for sure was at TDC.
    Also, I aligned the marks on the distributor and the rotor, but they should be at a specific orientation like pointing to the edge of the engine or point to the top?
    Any help or advice would be greatly appreciated!
  • pscouto
    replied
    Hey everyone,
    After a couple of productive “after-dinner” wrenching sessions, I finally managed to get everything assembled! Tomorrow, the new fuel filter arrives to replace the old, fill it with coolant, and then… ladies and gentlemen… it’s finally time to fire it up!
    That’s right—after some much-needed “spa time,” my Coupe Quattro is nearly ready for its first start.
    Before I turn the key, I’ll be going through a checklist to make sure all the critical things are in place and taken care of. I just wanted to say a big thank you to everyone here for your help, input, and advice throughout this process it’s made a real difference for someone like me that never did this type of work.
    Any last-minute advice for a first start ?
    What you'd double-check or do differently based on your own experience?
    Again, Thank you!
    Cheers,
    Pedro
    p.s
    I bought a gadget to use with the compressor to avoid air in the cooling system. Anyone had experience with this device?
  • pscouto
    replied
    Originally posted by RTurner992
    Great progress on restoring this! I’ve been following your progress as I’ve been working on my 7a I bought 6 months ago (trying to figure out a rattle at 1100rpm, I won’t hi-jack your thread with the details), but it’s good to see someone else tackling most of the things I’ve done within the past 6 months for comparison.
    The sensor with the blue tape is the fan after-run sensor. I’ve attached some pictures to show how that’s mounted. It uses one of the bolts through the valve cover, the same as the bracket opposite for the crankcase breather. It's very difficult to take a good photo, so I’ve taken a few from different angles, so hopefully, you can figure it out from those.
    I also noticed that I think your idler might be the incorrect size. I had that idler fitted to mine and didn’t bother changing it when I did the cam belt, water pump and crank pulley. As I was (and still am) trying to solve my issue, I started eliminating other components and realised then that it was the incorrect size according to ETKA. From the way the lip is on yours, it looks like the 68mm idler, whereas it should be 74mm. The INA part number for the 74mm is 22009601. It could already be the 74mm one, but it might be worth checking while you’re at this stage.
    RTurner992, you were right — the idler pulley is 68mm.
    I ended up buying the 74mm one, but looks like I’ll need to pull the crank pulley first to make it work. I’m going to hold off until the bracket arrives that locks the crank so I can safely remove the mighty bolt.
    Thanks again for the heads-up!
  • RTurner992
    replied
    replied
    And i think you just discovered why there was so much rtv inside your sump
    replied
    Well done. Looks like you are making progress.
    I don't think the wire orientation on that sensor will make any difference. Looks like a thermal sensor so just measuring resistance between the two wires. The one below ( cotton reel) is important. If not correctly fitted, your oil pressure will jump to max on the aux gauge as soon as you switch the ignition on. Test this while you have room.
    Hopefully you used thread lock on the top pulley bolt and supported it whilst torqued up?
    I had the keyway fail on one of my projects due to another mechanic incorrectly doing this
  • pscouto
    replied
    Originally posted by Tractor Dave
    Someone has done the head before and marked the valves to aid re assembly. You have done a good job on the sump and the pistons. I can't see from the angle of the pic but those two circles on the camshaft sprockets must line up with the cylinder head top. You should be able to feel any play in the big end bearings by grabbing a cap and pulling it back and forward. Not a very accurate test and the best way is to remove one and inspect. But if you dont have the confidence to do that, Fully understand. Plastigauge is the best test.
    Using brake cleaner to clean the lower half of the engine internals would not be my choice. It will wash off all the oil and leave the bearings dry for the first start. Heating oil would be a better choice, sprayed onto a lint free cloth and then wiped down. The bearings need some lubricant on first start which is why we use assembly lube when re building an engine. Did you use something on the camshafts?
    Be careful when the head is reassembled. Some wood at either end will protect the open valves.
    I would replace the short coolant hose that runs from the thermostat housing to the hard pipe. It's known to fail and difficult to get at normally. You can use coolant rated silicone hose which will last forever.
    I used "ajulube" on the camshafts is from ajusa, the same brand of the gasket kit.
  • pscouto
    replied
    Hello!
    Super busy at work lately, but I was finally able to carve out some time this weekend to get a few things done on the car. Feels good to make some progress!
    The head is in place now. I cut the heads off two of the old bolts to use as guides, and I think that made the job a bit easier. Definitely trickier doing it solo, but after earning myself some future back problems, I managed to get the head set on the block.
    I went through the two torque stages and did the final 180º turn. Had to practice a bit with the angle gauge before going for it, but in the end everything went smoothly—thank God! Rechecked the timing circles to make sure everything was aligned, along with the flywheel "0" mark… at this point, feeling pretty confident.
    Time to add the distributor. Aligned the timing marks and got the cover on—again, smoothly. I'm always bracing for some catastrophic error to pop up out of nowhere, but so far, so good. Let’s keep going!
    Placed the water pump, and since I didn’t remove the crank bolt and the belt was new, I just put the belt in the correct orientation and tightened the water pump bolts to set the tension—able to turn it 90º with fingers—set!
    Then I rechecked the timing marks and noticed the flywheel mark had moved about 1cm. The camshaft timing circles were still aligned, but when I tightened the water pump bolts and added tension to the belt, it seemed to translate into movement at the flywheel. So I removed the belt, realigned the flywheel mark, and repeated the water pump bolt tightening—but it shifted again by the same 1cm.
    Since it was consistently moving the same way, I reset everything and this time compensated by setting the flywheel 1cm in the opposite direction before tensioning the belt. Jackpot! After tightening the water pump bolts, the mark landed right where it should. Uff. Keep calm and carry on!
    Next up: the exhaust manifold—tried to fight me. But with a well-executed Karate Kid move, I went under the car and pulled the bolt that was holding the exhaust near the cat and voilà! “Who’s the boss now, motherf***?!” I may have said some nasty things to my manifold… I just hope one day it recovers from the trauma. Anyway, it's in place. I don't want to talk about it anymore.
    Now to the strange part of my car—the sump. It's a mystery. There’s no record of any crash or incident that would explain why it needed welding, but here we are. Even the small one has a patch job on it. The thing is… my car was at a garage where the guy had a Coupe Quattro. And look—I’m not accusing anyone—but let’s just say the thought did cross my mind: maybe, just maybe, a little sump swap happened when no one was looking. Who would notice, right? ?
    But now, there’s nothing I can do except either mend what I’ve got and keep going, or go on the hunt for a proper replacement. One more mystery in the life of this car.
    I placed the gasket and used little zip ties through some of the bolt holes to hold it in place—otherwise it’s a nightmare trying to balance the sump in one hand while keeping the gasket aligned. I don’t know if that’s the “proper” way to do it, but hey, it worked fine. Torqued everything down, even the ones specifically designed to complicate your life—yeah, the ones where you have to rotate the flywheel just to see them (thanks, Haynes for the info!).
    Time for oil!!
    And damn... i started leaking like it wasn’t even tight. Looks like the Sump Soap Opera™ just got another episode. Stay tuned for the next drama!
    So... time to remove the little guy again. That’s when I noticed one of the bolt holes was strange—it had been mended and welded. ****, ****, ****...
    Anyway, time for a solution. What I did was use a larger bolt, and behind the gasket, there was an imperfection that seemed to be a path for the oil to escape. So I must confess—I used RTV. Yep, I’m ashamed to say it! Ladies and gentlemen, I used RTV on my sump. Just a tiny bit behind the gasket, like a micro portion to compensate for that imperfection.
    Anyway, it worked! Refilled the 4.5 liters of oil, and after a long period, no leaks! I know that when the oil heats up, it might start leaking again, so… if anyone knows where to buy a sump, please let me know.
    But for now, let’s continue.
    Installed the inlet manifold, injectors, and used the old spark plugs to close the holes.
    Also, what do you guys recommend for spark plugs? I currently have Bosch, but I’m not sure if they’re the correct ones. I want to order new ones and want to make sure I get the right type.
    Since the beginning, I’ve been using a head camera to track everything I do—super helpful to remember where stuff goes. Until now, it’s worked great. But I discovered that it ran out of battery right when I removed a sensor near the hard pipe that runs from the engine breather to the inlet manifold (see photo with blue tape). I have other clips that almost show it, but I can’t quite figure out where it’s supposed to bolt back in.
    Can anyone help identify where this sensor mounts? Much appreciated!
    Also—what’s the best way to clean the throttle body? I used this degreasing BBQ cleaner called “Mistolin” (it even says on the bottle: “keeps the characteristics of the material”), and honestly, I’m loving it. It cleans everything really well, super fast on carbon. Can I use it on the throttle body too? Or should I be more careful with that area?
    Again, thanks for all the help!
    P.S. Regarding the main bearings—I decided it’s better to finish what I’m doing now, and if everything goes well, I’ll take it to a mechanic later for a proper check. If they need replacing, better to do it with a proper lift and tools.
    replied
  • pscouto
    replied
    Another thing, does anyone have the engine breather hose or know where i can get one? Mine seems to have colapsed...
  • pscouto
    replied
    Starting to get everything cleaned up! I just got the cylinder head back from the machine shop, and the timing i think is ok, but i could use your opinion.
    One thing caught my eye though: the valves have small dots marked on them (see attached photo). Is this a standard procedure? Just curious if anyone has seen this before or knows why they do it.
    Also, I wasn't fully happy with the state of the sump cover it still felt a bit dirty. So I got a barbecue cleaner and cleaned it better.
    Also did the inside of the sump, with brake cleaner and a microfiber cloth, I was not able to remove all the carbon. Tomorow i will go back at it.
    Then I attacked the pistons. What do you guys think? There are still some tiny marks from the gasket, but tomorrow I’ll try to take them off with a razor—at an angle and very, very gently...
    Regarding the rod bearings, tomorrow I will inspect them. If they need to be replaced, what do you guys think about this option?
    https://fcp-engineering.com/en/2t-20...-bearings.html
