S2 Coupe Down Under
  • Solfella
    • Aug 2025
    • 117
    • Country: Australia
    #61
    Ordered - with bolts - SKF VKBA 3605 and VKBA 1355
    Doesn't seem to be in Australia, so coming from Europe at 128 Euro, delivered
    1994 ABY Audi S2 | 1991 CQ20V - gone | 350bhp built Subaru Forester - gone | 2013 Land Rover Discovery 4 SDV6
      • Dec 2017
      • 5996
      SKF are good if you are getting a genuine one. Lots of fakes about!
      • Solfella
        • Aug 2025
        • 117
        #63
        I hope they are Dave. I've been using Spareto. Reviews suggest they deliver genuine parts. We shall see.
        • JayCab
          • Mar 2025
          • 195
          GKN Lobro
          • Solfella
            • Aug 2025
            • 117
            #65
            Now I'm going under the car, preparing for taking out the running gear and spraying everything worth spraying with penetrating oil, I'm starting to notice a couple of potential issues it would be great to get forum feedback on.
            Overall the car looks pretty clean underneath, very little if any rust and not much in the way of oil leaks as far as I can tell. A little history - the car has done 112K kms or 70K miles in its 32+ years. All the oils and fluids were changed before I acquired the car about 18 months ago. I had the engine oil tested and all came back A OK.
            Some pics of the underside:
            The areas where I thought something might be going on are here, near the front of the sump
            And maybe the rear diff
            There is one niggle I have which is that the clutch is really quite a challenge. It has a quite an aggressive bite and the heavy feel makes modulating it, and pulling away smoothly from standstill quite an art. It's been over 20 years since I last owned a coupe (then a CQ20V) since when, muscle memory (and my ageing muscles) means I'm far from being able to compare and contrast. Clutch is new and was also changed by the previous owner, at some cost, only about 3K kms ago. It is a Sachs sport clutch kit with single mass flywheel from 5Inline. I have receipts for its fitting which was also not cheap.
            Allied to this is noticeable shudder - often in reverse but also sometimes when pulling away at low revs. I'd discounted this being related to the clutch as it is new, but could I be wrong? It doesn't do it if I feather the clutch carefully (difficult given the above) and/or get the revs up. I was wondering if some of the drive train bushes and various mounts are contributing, given their age, rather than the miles driven.
            • Jaswan
              • Apr 2011
              • 772
              #66
              Are there any signs of oil between the engine and the gearbox bell housing? Do you know if the rear main oil seal was changed with the clutch?
              I also had similar judder with a new clutch (well, shortly after it was brand new). When I thought about it I was annoyed at myself for not changing the rear crank shaft oil seal while the flywheel was off. Although I didn't see much signs of a leak on my car, in my head I put it down to some slight contamination of the clutch from a faint leak from the back of the crank shaft.
              If I was to deliberately to slip the clutch to "clean" it off, it would be fine for a period after. This reinforced my theory.
              In my opinion the judder has to be coming from the clutch gripping and slipping.
              Jase.
                • Dec 2017
                • 5996
                Check the oil level in your rear diff. If it's still full, I wouldn't worry too much about that wet area. Just keep an eye on it.
                Unfortunately, the Sachs sports clutch is well known for being heavy and the judder will be from the SMFW. The standard clutch kits are nla. If you can find a second hand one, they can be refurbished.
                • Solfella
                  • Aug 2025
                  • 117
                  #68
                  Thanks both. Yes, the rear main was changed Jase. And good to know Dave - it wasn't until recently that I found out the S2 was originally a DMF set up.
                  • Solfella
                    • Aug 2025
                    • 117
                    #69
                    I fired off my previous post in haste this morning but it got me thinking, and then disappearing down a rabbit hole of discussion about DMF vs SMF, including on this forum. That isn't to say I am thinking about changing clutches anytime soon, if at all - I'm just curious.
                    I understand there are trade-offs either way, not least of which is the clutch judder on an SMF and that availability/cost is just one of the reasons for going to SMF over DMF. Likewise ability to handle upgraded output could be a reason for going to a SMF. My car will be going to RS2 spec - didn't that come out on a DMF? That said, if one goes to SMF, is there a 'sweet spot' where judder and chatter are minimised and the stop-start experience optimised in our cars (e.g., FW weight, balancing, specific combination of clutch parts/manufacturers)?
                    Then of course, the 'heaviness' of the pedal is a related issue. Faced with a similar problem on my Subaru with a puck HD clutch, I was able to lighten the clutch somewhat by using a slightly oversized slave cylinder, which worked well. That and a combination of a clutch pedal stop worked wonders. I think I read somewhere on this forum about alternative arrangements derived from other vehicles. I've also read elsewhere (not about our cars) of people incorporating a VH44 brake booster from a Mini Moke into the clutch hydraulics ... but I'm disappearing down rabbit holes again.
                    Anyway, as I say, just curious
                    • Jaswan
                      • Apr 2011
                      • 772
                      #70
                      Just for context, my judder was with a full sachs DMF kit.
                      • Solfella
                        • Aug 2025
                        • 117
                        #71
                        They turned up - look to be the genuine item as far as I can tell
                        • Solfella
                          • Aug 2025
                          • 117
                          #72
                          So, I've been under the car again and had a good look at the gearbox to bell housing joint. Seems a little oily perhaps? And am I right in thinking this has the spacer in place that would normally be there if it were a DMF - and yet I know the car has been converted to SMF, or am I missing something?
                          I've been debating pulling the motor out for various reasons - perhaps this adds another one.
                            • Dec 2017
                            • 5996
                            Difficult to say but i think that oil is tracking from further up. Rear main and gearbox oil seal would be coming from that little window in your last pic, which looks dry. I've never fitted smfw so not sure about the spacer? I would think it depends if the flywheel has been machined to original dimensions or not?
                            • Solfella
                              • Aug 2025
                              • 117
                              #74
                              All good points. Thanks Dave. You're a star. Lots for me to learn about theses cars it seems.
