S2 Coupe Down Under
  • Solfella
    • Aug 2025
    • 122
    • Country: Australia
    #76
    Originally posted by Solfella
    They turned up - look to be the genuine item as far as I can tell
    Not much to report at the moment while awaiting the windscreen and contemplating my next tasks (see below), but I stumbled across this SKF authenticate app recently (https://www.skf.com/au/digital-tools...p/authenticate). Apologies if known already. Anyway, and according to the app, pleased to report mine are the genuine items, from Spareto in Lithuania.
    Speaking of next tasks, I am, for a variety of reasons, moving closer to wanting to take out the motor with gearbox. This would give me access to lots of things I want to get to - replace hoses, radiators, sensors, fit vacuum brake conversion, change IM and EM, turbo and down pipe, bushes and mountings, etc, etc, as well as allowing me to generally clean and smarten everything up in the engine bay. Tell me I'm crazy, but I am seriously contemplating restoring the dual mass clutch from the current single mass for a better day-to-day driving experience.
    All that aside, I'm looking for advice on the removal procedure. Best I can glean so far is after dealing with removing the front of the car, unhitching electrics, fluids etc, to then support the gearbox and remove the subframe to give better access to drive shafts and gear box linkages before removing engine, complete with the down pipe attached, through the front of the car. How does that sound?
    I have a two post lift at home and can get access to engine crane, transmission jack, and one of those support bars that sits across the inside of the front wings. So I guess I'm asking with all of that equipment to hand, what's the most sensible, most straightforward procedure?
    I also have plans to completely refurb the suspension and replace the brakes so they may as well all come out at the same time. I'm a little apprehensive about the time it would take to do all of this but semi-retirement means that luckily, I can afford around 4 full days a week. And this project is my kind of retirement hobby more than anything.
    Any opinions, BTDT advice, or words of caution much appreciated.
    1994 ABY Audi S2 | 1991 CQ20V - gone | 350bhp built Subaru Forester - gone | 2013 Land Rover Discovery 4 SDV6
      • Dec 2017
      • 6015
      If you have a two post lift, its all very easy. Drop the engine and gearbox together onto a pallet or similar under the car. I leave shocks and struts on the car but you can drop everything in one go. Just support everything from above using your crane as you undo everything and remove driveshafts etc. Lower it slowly onto your support the use the lift to raise the car leaving engine and gearbox behind. Simples.
      • RedV6
        • Jun 2026
        • 83
        Yea as above is the best plan. Gives you loads of easy access to work and clean.
        • Solfella
          • Aug 2025
          • 122
          #79
          Excellent - thanks fellas. I was hoping that would be the case!
