Red V6 Just needs a bit of polish..!
  • K Simmonds
    • Dec 2007
    • 7627
    Originally posted by JayCab
    Subjectively, I'd say a 2.8AAH Automatic Cab feels about as fast as a 2.6ABC manual coupe in average driving under 3kRPM, but twice as smooth. Delivery is very different above 4kRPM. An AAH will behave a lot like an ABC if the vacuum system driving the inlet manifold switchover is not working. Maintenance is important!
    Both are more cruisers than bruisers
    Yep, agreed. My AAH C4 Avant is lovely and easy to drive, super smooth and refined with heaps of low down torque, fortunately the previous owner properly overhauled the complete vacuum system so it will pick it's feet up if required despite being a heavy car. I've had a couple of ABC Coupe's which sadly got broken back when they could be be acquired very cheaply and really enjoyed cruising about in them while they still had MOT. I'd say the 2.8 C4 is as about as quick in a straight line a 2.6 Coupe due to the weight difference but as you say they're not really designed for being driven flat out, that's what 7A's and S2's are for.
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    • RedV6
      • Jun 2026
      • 73
      Been a bit distracted lately with the kids flat and other life stuff but have now finished the second coat on the underneath. Am just waiting for some colour match for the engine bay which is all prepped. So today I managed to carry out a bit of loose reassembling, it feels good to put a few bits on!
      This gallery has 4 photos.
      • RedV6
        • Jun 2026
        • 73
        Not too much to report other than I have now finished "rattle can'in" the inner wings with some colour match paint. The left one came out really well and the right one, passable but still a huge improvement on how it was. I didn't do the firewall as it was in good shape overall and I was trying to avoid removing the wiring harnesses, so I just gave it a good clean.
        Next step is to remove the engine from the scrap (damaged and rusty) Cabriolet. My plan there is to use its engine and gearbox as it has a great service history and it starts, runs, and drives very nicely. Plus it has air con, which the Coupe doesn't. Not sure how much I will need to swap over but I suspect a lot!
          • Dec 2017
          • 5992
          Looking good. I did my Nothelle engine bay with rattle can and it came out surprisingly well.
          Quite a lot to swap for air con. The dash will need to come out to swap the airbox and the glovebox is smaller. Are the aircon pipes in the offside arch ok? They rot out and are nla.
          On the S2 the actual sump extension and front stub mount are different on aircon cars.
          • RedV6
            • Jun 2026
            • 73
            Thanks Dave. Interesting stuff. I will take a load of pics and post them.
            The pipes all seem to be in the engine bay. From the compressor they go forward under the radiator, then one to the dryer (underneath the right headlight) the other to the right of the condenser. Then round the engine bay (engine side of the right inner wing). Then back hight up on the firewall almost above the engine and inside directly in front of the glove box.
            Regarding the glovebox is the dash the same and the box just smaller?
            • John.
              • 2615
              Originally posted by RedV6
              ............ Plus it has air con, which the Coupe doesn't. Not sure how much I will need to swap over but I suspect a lot!
              I'd be asking myself the work to benifit question ?!, but I'm not you !
              Great job you're doing
                • Dec 2017
                • 5992
                Yes. Coupe dash is the same ac/non ac afaik. Just a smaller glovebox. Cabriolet dash is different. It has extra tubes in it to strengthen and reduce scuttle shake. On the S2 the drier is inside right inner wing and gets all the mud and salt on it and pipes to and from.
                • RedV6
                  • Jun 2026
                  • 73
                  Thanks Dave, handy information. I expect the scary bit will be trying to undo the pipes! AC doesn't work on the Cab but it does still have gas pressure, the ac and recirc buttons light up and the condenser fans operate as and when they should so I am sure I can get it working.
                  Thanks again for the info. Paul
                  • RedV6
                    • Jun 2026
                    • 73
                    Possibly not. I almost enjoy the challenge of the work and the satisfaction of creating a fully a working machine, from something we dragged out of a field, than driving around in the finished car! Plus we had an almost Identical red one all those years ago.
                    I could just go an buy a mint one which I agree would probably be more sensible but then I'd have some spare time and I would end up buying something else.
                    Cheers Paul
                    • John.
                      • 2615
                      Cheers Paul
                      Totally understand .
                      • RedV6
                        • Jun 2026
                        • 73
                        Dash is now out of the scrap Cab, heater and evaporator units removed. Have reconnected most of the wiring so that it still starts and drives. Plus I can retest the fan and the recirculation solenoid to check they work.
                        Next it will be back to the Coupe to remove the dash and heater so that I can compare and figure out the a/c wiring. Perhaps if I am really lucky it will have a stand alone loom etc for the a/c and will just plug in. Although I very much doubt it.
                        One question! Does anyone have a view on what to use to replace the degraded foam on the heater and recirculation flaps. I was thinking self adhesive neoprene sheet!?!
                        • RedV6
                          • Jun 2026
                          • 73
                          Had a bit of spare time today, so decided to see if I could test out the AC and recirculation flap operation.
                          I spread out all of the dismantled heater box inside the Cab and jumped the pressure switches for the low pressure and the two high pressure switches (condenser removed) and no gas. Started up. Hey presto, flap operates and compressor starts, I just ran it for a few seconds but there was plenty of oil visible in the pipes and condenser so the compressor would have had also.
                          So back to the Coupe!
                          • YELL MAN
                            • Dec 2005
                            • 541
                            • Country: Shetland Islands
                            #43
                            For the heaterbox flaps I used 3mm self adhesive neoprene, seemed to work a treat
                            1994 Indigo Blue S2 coupe
                            1994 80 Avant 1.9 TDI
                            2005 Yamaha Fazer 1000
                            1953 AJS Model 18S
                            • RedV6
                              • Jun 2026
                              • 73
                              Thanks. Yea what's left of the original foam was about 3mm. I'll go with that.
