MY96 RS2 light resto project
  • Skinkis
    • Jul 2026
    • 37
    • Home: Sweden Current: Australia
    So this is the ongoing story about my RS2.
    It all started at work one day, my colleague kindly left an ad open on my computer whilst I was out grabbing some lunch.
    I wasn't in the market for a new car, I currently had a CLK63 that suited my weekend needs perfectly.
    My colleague knew that I had previously owned an RS2 many moons ago, and that it was one of the cars I wish I had never sold.
    I got back from lunch and fired up the computer again only to see a low kms (54k kms) Brunei import RS2 sitting at a dealer in the Eastern states.
    I flicked the ad to the wife who quickly gave it the tick of approval, so contact was made with the selling dealer.
    Because it was located 3300 kms away, I booked a PPI with the local Porsche dealer.
    The PPI came back with some age related issues and a note that the vehicle would occasionally stall and it ran a bit rough.
    Since imported to Australia in 2022 it had around $30 000 spent on it to get it up to scratch to pass its roadworthy inspection.
    Going through the receipts gave me some comfort that majority of the age related issues such as fuel system, suspension, brakes and steering had all been taken care of, and it past a roadworthy in 2025, so how bad could it be, right?
    I put the rough running and stalling down to needing a service, fresh fuel and a good run, no car likes sitting around doing nothing, and it had only done 2000kms since being imported in 2022.
    A deal was struck and the car was sent across to Western Australia.
    Day of arrival.
    thumb_94493.jpgthumb_94345.jpg​
    I popped it on a hoist at work and gave it a look over, cleaned it down and booked it in for an inspection to see what they would find and what I would need to get rectified before I could get it registered.
    It failed it initial inspection based on the following:
    -electric windows working intermittently.
    -interior d-pillar trims missing. ​
    I took a couple of days off work to get these items fixed, the d-pillar trims were a surprise, didn't expect that to be an issue, but here we are.
    I couldn't find any for sale, so I made a template out of cardboard, then cut them out in .4mm aluminium which I shaped in roughly the right shape.
    I then covered them in black fabric and popped them in with some trim clips.
    Not the neatest, but will do until I can find some proper d-pillar trims from an Avant for sale somewhere in the world.
    thumb_94496.jpgthumb_94497.jpg​
    With the window switches I figured it would likely be a wiring issue, what are the odds that all 4 switches fail at the same time?
    I pulled the door card off and found some of Brunei's finest tape n twist on a few of the wires.
    I undid that and soldered it all back together, now we had 4 working switches again, life was all good!
    thumb_94500.jpg​
    I booked a re-inspection the following day and made my way there.
    About 5 minutes out, the car decided to drop a cylinder.
    Much rage. I rang and cancelled the inspection and limped my way back to work.
    We worked out that it was cylinder 5 that died by undoing an injector plug at a time, I popped a set of fresh plugs in with no improvement so assumed it needed a new coil. At this point in time, I decided it would be a good idea to upgrade to the newer TFSI coils, it certainly would not hurt with a fresh harness and 5 new coils, so an order was placed from 5inline.
    Whilst waiting for the coil kit to arrive, I did more research and came across a fair bit about failing POS units.
    I decided to check mine, and low and behold, it turned out that one had died.
    I ordered two fresh ones and popped them in and the car ran beautifully on all 5 again.
    I got the re-inspection done, collected my new plates and drove the car home.
    The more I drove the car over the coming days, the worse it started to run.
    To the point when I would cold start it, it would run for 4-5 seconds, then drop 2-3 cylinders and eventually stall.
    Every restart it was the same, run on 5 for a few seconds, then drop to 2-3 cylinders and stall.
    Until it got some temp in the engine, it would then pick up a cylinder until it would run on all 5.
    It still didn't run all that well, so it was time to get stuck into it and see what was going on.
    The TFSI coil kit arrived, so I installed it, just to eliminate any spark issues.
    I found a couple of air leaks from split hoses between AFM and turbo, so I replaced them.
    thumb_94502.jpgthumb_94506.jpg​
    The more I dug around, the more age related issues I ended up finding.
    The worst part was that a lot of these issues had been "rectified" by the workshop who charged the previous owner $30k over the years.
    The lower boost hose had been repaired with what looked like self amalgamating tape, I didn't like it, so I got a black silicone hose kit and replaced all hoses.
    I also found a no-name aftermarket old BOV fitted which looked heavily corroded, so I replaced that with a fresh plastic one from 5Inline.
    The air filter was an aftermarket panel filter, it was super dirty, and it was so old that the rubber seal had started to split and was letting dirt through everywhere, so I replaced that with a new paper filter.
    I found that the throttle body did not open past 75%, a hose clamp had been installed the wrong way and fouled on the throttle body.
    All these small improvements made absolutely zero difference to the running of the car, it still ran really bad.
    I decided that I needed help with the diag and I needed someone with access to VCDS or the like as we only have OBD2 tools available at work.
    I found a small local business that specialise in this era Euro cars, and they had access to VCDS.
    We went through and checked codes and all sensors.
    The one that kept coming back was o2 sensor out of range.
    All things pointed to the fuel system, which I didn't really want to accept given that I again had receipts from previous owner, having replaced the fuel pump, FPR, fuel filter and having the injectors serviced.
    I sat on it for a few days before I decided to open the tank and see what was going on in there.
    Getting the fuel pump out revealed a few things.
    About half the sand and dirt in Brunei was in the tank, and the pump hanger was broken so the pump could move about, given that the inlet of the pump is offset, I figured that the pump may have been able to swivel a touch to cover the inlet which would not be great for the flow.
    The line from the pump also had a small kink in it.
    The level sensor had also seen better days, so I ordered a new level sensor and fuel basket from Audi Tradition.
    In the meantime, I wanted to get a basket tool, having read Tractor Daves wicked build thread, I decided to contact him and ask if I could have the file for the tool that he had 3D printed. He kindly sent me the file, so I asked my friend to print me one.
    a43d300a-b4e4-44f8-914d-992f1d342540.jpg b225537f-5a6b-46be-ab2b-635bb635acdd.jpg e5960581-db12-4770-9840-2ab89e407af0.jpg daf601ca-7de0-4bd9-b0f8-a851c8668082.jpg e568e17d-19fe-41b6-88ac-ee135fa894c3.jpg
    Whilst waiting for the new level sensor and basket, I set out to clean the tank.
    I pumped it dry and cleaned what I could with rags.
    I then put 10 litres of fuel in it with fuel cleaner, ran a rag over as much as I could reach, pumped it all out, filtered the fuel, back in again, pumped it back out, filtered it, and repeated that until no more dirt would get stuck in the filter.
    The new basket and level sensor arrived, I popped that all back in, and decided to flow test the pump, I figured this would also let me know if the fuel filter was blocked or not.
    The flow test came back within spec, and no dirt ended up in the sample either, happy days!
    I then pulled the injectors and dropped them off to a colleague that has a flow bench at home.
    3 sessions in the ultrasonic cleaner and flow bench, and we still couldn't get injector 5 to be happy, it was roughly 15% less flow than the other 4.
    I decided that a new set of injectors were needed, so I started researching what would work as a replacement for the discontinued OEM injectors.
    I found some Ford injectors from the US with near on identical specs, so I ordered a set of 6 hoping that they would do the job.
    After installation I turned the key, and it fired up straight away on all 5.
    Much relief, it finally ran the way it was supposed to.
    This pretty much brings us up to date, so next on the list of things that I want to do is:
    -noisy alternator bearing require rebuild.
    -AC not working, no belt fitted and condenser looks tragic.
    -radio not working, wiring has been cut behind the original radio.
    -fix the little LCD screen on the dash which has delaminated.
    -window tint.
    -exhaust.
    -lowering springs or coilovers.
    -18" wheels similar to Keskin KT2 or the like.
    The goal is to have a nice weekend cruiser that makes the right 5 cylinder noises, nothing extreme and nothing that can't be reverted back to OEM.
    To be continued
    This gallery has 16 photos.
  • A1quattro
    • Jul 2006
    • 791
    hi glad your heading in write direction good write up. can you post info on the replacment injectors
      • Dec 2017
      • 6017
      Nice work. Happy to help any time. Looks great
        • Dec 2017
        • 6017
        PS. I can probably find D pillar trims here in the UK as they are the same on the 80 Avant if a different colour. You can paint black. Let me know if you want me to hunt.
        • Alburglar
          • Oct 2017
          • 65
          It's nice ticking the boxes on jobs.
          And you won't regret sorting a load of the age related engine bay niggly bits, all in one go.
          • Skinkis
            • Jul 2026
            • 37
            They're Bosch# 0280150967
            Came from a 3.8 supercharged V6 from the same era.
            They are now also listed NLA as new, but you have a much better chance of finding these injectors as NoS or rebuilt units.
            I found a company (MotorWest Performance) that sell flowmatched rebuilt sets with a 2yr warranty, so I took a stab and it appears to have paid off.
            • Solfella
              • Aug 2025
              • 124
              • Country: Australia
              Great write up and the car looks terrific. Love the rego plate.
              I had similar fuelling issue symptoms but was able to trace that back to dirt somewhere between the tank and fuel filter.
              My car (S2) came from Perth (I'm in Cairns). I don't know who you went to in WA, but the fella I bought it from had been using a local independent called G-Spec, who apparently have some knowledge of our cars. Side note, I have, just recently, found a local here who did his apprenticeship on the B3/B4 platform.
              Shout out to Tractor Dave and others on this forum; their willingness to freely provide helpful information and advice is amazing.
              1994 ABY Audi S2 | 1991 CQ20V - gone | 350bhp built Subaru Forester - gone | 2013 Land Rover Discovery 4 SDV6
