Well here,s another idea, is it possible to put the 20 valva 7A head onto the WR block to achieve a 20 valve turbo ?, also can anyone sugest where i can get bigger valves and high lift cams. I am also looking into getting a bigger turbo so can anyone sugest a larger direct replacement.
Apart from the engine i also need a roll cage for the WR and i have some Red 4 pot Porsche calipers so does anyone know where i can get the bracket to mount them. Thanx,,,
20v ( 5 syl)head will fit old style audi block: some minor holes for the water,you may drill if you want( 3mm)
BUT some old style block have only 79,5 and even 2,0 diesel have 76,5 boresize... the valve may have contact in the upper sylinder, if you use high lift camms...( the go down in the sylinder) and have the piston valvecuts for the space?? piston and valvesalads arent healthy for the engine
