Project Avant+
This topic is closed.
  • 4WheelDrifter
    • Oct 2004
    • 5773
    • Country: Devon
    Originally posted by Corey
    You may not see the pump as a problem, I do.
    Ok. I can see it is in your interest for Ross to have a new pump if you're doing the work.
    SS
    • Fat Audi 80
      • 10547
      I would have a new oil pump if I was rebuilding an engine.
      What are they £40? Cheap insurance policy IMO...
      Cheers,
      Steve
      The Perfectionist
      • Ross
        • Aug 2005
        • 3399
        LOL...
        As for the oil pump, I guess at £250 it's one of those things I'd be tempted to not replace... parts alone are gonna eat all my budget for this one! If it all looks perfect then maybe it can be used again. But I'll probably end up using it... plus, I can understand that Corey doing the work would not want it to fail and then be tarred for doing a crap job!! Wanna ensure this is done once and done right. And I PROMISE to avoid big brick walls in future
        The 034 valves are a bit of an experiment really, I'm intrgued to see what difference they make (techincally, what should they do? lol) and want a good head after all, I like to exceed my goals :mischeif:
        • GT500
          • Jun 2006
          • 2181
          Cheers,
          Steve
          No, they are £250! bloody stealers!
          Anyone want a 80,000 mile RS2 oil pump thats knackerd? they don't last for ever!
          Rob..
          87 UR 20v ABY
          97 S6 Avant
          • Fat Audi 80
            • 10547
            Originally posted by Ross
            LOL...
            Really!
            Shows what I now about building S2 engines.
            *slumps off back to detailing Forum*
            The Perfectionist
            • Rusty
              • 18953
              They should increase efficiency at higher flow rates and therefoer allow for higher power, Are you combining this with high lift cams for maximum effect? And, are you getting any of
              • Head ported & polished.
              • IM / EM port matched to head.
              • EM polished (be a good idea if you're trying to minimise exhaust losses).
              Be interesting to see the results as it's not common practice as, having seen an S2 head recently, they really don't look very restrictive!
              Good luck Ross, you lucky sod
              • CHEN
                • 329
                I had the little argument in my head about whether or not its worth doing a new oil pump on my car. Although I almost never see the 5cyl running with oil pump problems, its a big thing not to change, we all know what happens if it fails. I decided to go on the side of caution and change it. That said 3B pumps are best part of £100 cheaper.
                • audiman
                  • 4827
                  What engine bits are you using then Ross?? Surely its just a case of chucking the 3b lump straight in with the ABY head? If thats the case, then why do you need to change the oil pump, the old one was spot on IIRC..
                  I think you will disapointed with the gains from big valves on your setup. I guess it depends on your future mods. But std valves have been used on power outputs over 600bhp.
                  ARP bolts would also be a good idea whilst its apart for peace of mind, but having said that, i had no problems when running 475bhp, but that must have been the limit as at 550bhp the head was lifting.
                  Tom C - www.rcmr.co.uk
                  Audi UR Quattro
                  Audi 100 C3 2.0 5 cyl 115ps
                  Audi B5 RS4 645ps 911nm
                  • Corey
                    Banned
                    • Sep 2003
                    • 2793
                    Ross wants to have the engine to RS2 spec (ie water pump etc) so the 3B pump is of no use to keep future servicing easy (ie he only has to remember one engine to get the bits for, rather than he needs x from this and y from that)
                    ARP's have already been spec'd for the head and the mains.
                    Tom I assume the rods you fitted in the block had ARP fastners already?
                    Not opened the old 3B lump yet so we don't know.
                    Corey
                    01636 822288
                    • Ross
                      • Aug 2005
                      • 3399
                      As Corey said - the intention was to push for a full RS2 spec pump + replacement cooler as that was what i wanted. I guess I could 'go 3B' just to make to project easier n cheaper, and require less new parts.
                      GTi is the goal so i may have to make a few comprimises, which goes against the grain, but I don't want to delay. Anyone wanna buy a kidney? Or 2 - I hear home dialysis is now available
                      The SPMs are fitted with ARPs, jobs a good 'un there. That bottom-end was balanced + built to "Tom's car spec"
                      • Jon441cc
                        • Dec 2005
                        • 2061
                        Are the main bearings being changed due to ross's insane need fo more power in the years to come
                        • Ross
                          • Aug 2005
                          • 3399
                          Look at this poor ABY lump, with that big ugly dual-mass beastie attached to it
                          The head that was removed is crack-free and ready for rebuilding with a few exotic parts that found their way across the pond :mischeif:
                          • Ross
                            • Aug 2005
                            • 3399
                            ...and here's the gap; what shall we put in here then?
                            • Ross
                              • Aug 2005
                              • 3399
                              ...a bit of work, and I was thinking this would do
                              With this 3B/ABY hybrid, does that make her "The Mule"?
                              • Jon441cc
                                • Dec 2005
                                • 2061
                                What you gonna do with the ABY bottom end ? Saving it for another rebuild maybe
                                Progress looks good buddy
                                PS : Who's blue RS2 ?
