project 500+
  • urquattro-island
    • Mar 2006
    • 1915
    • Home: Norway Current: Iceland
    #121
    and the
    nice rear small end pipes...
    japanischer industriabfall nein danke!!
    www.rackeltrim.se Icelandic Division
    • urquattro-island
      • Mar 2006
      • 1915
      #122
      today
      I refurbished the winter rims, some elbow grease and a few hours of work to wonders and a black spray can for about 5pounds. Will post some pics later today..
      • urquattro-island
        • Mar 2006
        • 1915
        #123
        some
        pics of the "new" rims..
        • Acidburn
          • 13459
          Nice work, blacks good on cars in the daytime or light but for good all round can't beat white wheels, really stand out at night and in the day especially on a red car.
          • urquattro-island
            • Mar 2006
            • 1915
            #125
            just
            a little update, ordered new front wheelbearing today. Got some slack in the left front one. And my new head gasket and manifolds gaskets, have arrived.
            Thinking of changing them next weekend. And now to the fun part, my freakin car is leaking , filles up with water in the trunk. water comes in with the lights by the look of things.
            Any ideas`?? is this a typical problem on these cars??
            I also need to change the oil seal on the right side of the tranny, driveshaft. anyone got the partnr???
            Just payed for a new 3"downpipe from sweden, made with to outtakes for wideband, since i will be using the original and the one i got from 034M.
            Ordered from corey also,
            1 Fuel Pressure Regulator, Drop In, Audi 3B 20vt
            1 Audi S2 5-speed 3B Spec Clutch Kit (3plus)
            2 sets of Subframe Bushings, Aluminum, Audi Small Chassis
            1 set of ARP studs
            Huge intercooler from one here on this forüm. Hope to get it soon aronmatic.,...
            Here is a pic of the missys car and mine..
            • Acidburn
              • 13459
              Yeah the leaking in the boot is a common problem, the rubber might not be sitting right or the lights might have lost the seal, is there any water in the lights?
              • urquattro-island
                • Mar 2006
                • 1915
                #127
                yes
                there is some water in the lights, but it is more in the boot. Any tips, where to buy new rubber or what to use??
                • Acidburn
                  • 13459
                  Just clean all the water out of the lights, i've heard of people doing some small little holes in the bottom of the lights to let the water out, new seals would be good, the rubber seal for the boot if in good condition probably needs re-seating.
                  Rear Taillight Leaks
                  Symptoms: Water visible inside taillight, water seeping inside trunk/hatch, water collecting in right side storage bin (Coupe). The foam adhesive between the taillight and the body can be a source of the leaks.
                  Remove interior trim, then unbolt tailight assembly from inside the trunk. (This may require removing the license plate and center panel -- be careful not to crack the panel.)
                  GENTLY persuade the tailight assembly to separate from the body. Patience is a virtue.
                  Pull off the old gasket, and clean the adhesive and gasket bits off of the body and tailight assembly.
                  Find an auto parts store or autobody supply shop that carries 3/4 inch butyl window "tape". It's sticky black and playdough-like. Try 3M 08614 for about $10. Apply it to the tailight assembly and remount on the body.
                  Reassemble all parts in reverse order.
                  If the leak water is collecting in the passenger side housing, the problem might be with the lock/push button release for the hatch. Push the button in and look for cracks. They can be sealed with silicone adhesive or other weather-proof goop.
                  Taken from 20v.org
                  • urquattro-island
                    • Mar 2006
                    • 1915
                    #129
                    ok
                    thanks
                    • Jas11n
                      • 5067
                      Link
                      2001 Avus Silver B5 RS4.
                      1995 S2 Coupe - sold (sniff)
                      • urquattro-island
                        • Mar 2006
                        • 1915
                        #131
                        aha
                        Originally posted by Jas11n
                        the gum trick
                        • urquattro-island
                          • Mar 2006
                          • 1915
                          #132
                          today
                          i got my new metall head gasket, new Im gasket and new metall Exh.gasket. So looks like the weekend is booked...
                          • urquattro-island
                            • Mar 2006
                            • 1915
                            #133
                            and
                            here are some figures on my new built engines, the one is 2,5ltr and the other is 2,6ltr
                            Diesel crank and blueprinted engines with certificate.
                            144 mm conrods
                            95.5 stroke
                            82mm bor 83 mm bor
                            Je pistons
                            scat and eagle forged rods
                            arp bolts
                            coated bearings
                            new oil pumps
                            engines built for 1000hp.
                            • urquattro-island
                              • Mar 2006
                              • 1915
                              #134
                              he he
                              done a little polishing again, and changed a wheel bearing. well time for more pics..
                              • urquattro-island
                                • Mar 2006
                                • 1915
                                #135
                                and
                                that was the before pic. tataaaa
