7A block to turbo spec rebuild
  • Azman
    • Sep 2005
    • 3205
    Cheers Jamo kidda. Will have to join another site then
    Dark Grey Avant
    RS2 FARB
    Alloy Subframe Bushes
      Originally posted by Jamo
      Azman head over to motorgeeks it's all covered there as this is a common conversion for the yanks.
      83 mm is the max you can run at personally i wouldn't as your at the limit.
      You can't go beyond 83mm with another rebore down the line. Stick with 82.5 and then you have 82.75 and then 83 as rebore in the future.
      Agreed with Jamo on this one... No point in maxxing out the block for this. 82.5 is plenty enough.
      Paul
      • Azman
        • Sep 2005
        • 3205
        Cool for cats...
        Dark Grey Avant
        RS2 FARB
        • Azman
          • Sep 2005
          • 3205
          would these do on scat rods?
          Dark Grey Avant
          RS2 FARB
          • Acidburn
            • 13459
            Also is there any returns to the sump for the turbo as these would need tapping in?
            • Azman
              • Sep 2005
              • 3205
              Not if you use a proper sump!!!!!
              Dark Grey Avant
              RS2 FARB
              • Acidburn
                • 13459
                Ok was not sure if it was in the block or sump? thanks for clearing that up.
                • Azman
                  • Sep 2005
                  • 3205
                  Hahaha..... Starting witht the block matey and building everything up form there and getting the whole lot properly balanced for smoothness. long project but will get there. Gettign the engine built before the car so i know it is done
                  Dark Grey Avant
                  RS2 FARB
                  • PeterS
                    • 425
                    Azman:
                    Javad's 80TQ uses started with a 7a block for what it's worth....
                    -Peter
                    Peter S
                    1990 ErsatzS2 - track toy
                    1991 Coupe Quattro
                    1991 Coupe Quattro
                    1995 S6 Sedan
                    1995 S6 Wagon
                    • 4WheelDrifter
                      • Oct 2004
                      • 5773
                      • Country: Devon
                      #25
                      You're just as well to stick a 95.5mm crank in there while you're at it, for an extra 243cc.
                      SS
                      • Azman
                        • Sep 2005
                        • 3205
                        Thanks guys I think sticking with the stock piston size will suit me best not after massive power (looking for around the 450 mark) so scat rods and JE pistons will do the job methinks....
                        All good.
                        Az
                        Dark Grey Avant
                        RS2 FARB
                        • BRY
                          • 3755
                          #27
                          Have you got one?
                          • WabTheKing
                            • May 2004
                            • 2567
                            im learning about clearances when building a race engine at uni at the moment, very interesting stuff!!!
                            also mind blowing the amount of thought that has to go into these things when you start swapping and changing from standard
                            go and get yourself a set of feeler guages - you will be using them alot! hope everything goes to plan for you dude
                            • 4WheelDrifter
                              • Oct 2004
                              • 5773
                              • Country: Devon
                              #29
                              Originally posted by BRY
                              Have you got one?
                              Not yet. Have you?
                              SS
                              • AndyP
                                • 6049
                                Not yet. Have you?
                                I've got two
