It's a proper hybrid turbo alright! it's based on a 3076R but with a smaller 48 trim on compressor ( standard 3076 is 56 trim ) and also a smaller hotside with 0.6 hotside ( smaller than 0.82 and 0.63 on standard 3076R hence the need for machining )
I'm fairley certain that G-Tech gives wheel horse power as it has no way of knowing transmission loss's, it calculates how quickley you are accelerating a known mass from a standing start. You only have to be a bit out with the weight you input and it can have a huge effect on the power it calculates. To be accurate you really need to take the car to a weigh bridge to get a wet/loaded weight.
Andy
probably then,cause 450 whp means more than 500 crank and i dont think it is possible with that turbo.
As g-meter owner, I can say, that you need to be precise on cars weight to show something around truth. Otherwise it can feel that my coupe with k26 has 400whp (lweight of V8 4.2 was left after earlier testing )
Sau
