One more 420hp project
  • KramRS2
    • 65
    Well,
    It is finally done. Almost.
    My car is a 1995 RS2, polar silver with 70.000Km. I did a lot of things with chips and filter and exhaust, but I put everything stock again before I did this mod that I will tell.
    From the stock RS2, ADU motor I changed:
    • Turbo –Water cooled center section, K26#9 or #10, I don’t know, but the “turbo guy” said that is good to 500hp+
    • Compressor – TO4E, with (50 trim equivalent size) different design from Garrett, A/R .50
    • New hoses from MAF to compressor inlet.
    • New, bigger MAF. A Porsche 928 (SQ also) aluminum unit.
    • 3’’exhaust, two on one from downpipe (21/2 ‘’on one 3’’). One Huge Flow Master at middle and one (almost pass through) muffler in the back;
    • Two auxiliary high pressure Bosch fuel pumps;
    • 710N diverter valve;
    • No breather hose to the intake. It is collected on an external bottle;
    • UNICHIP piggy-back computer with boost control;
    • 4bar FPR;
    I’m still using stock ECU, stock EM, stock downpipe (only a little machined on the flange to turbine exit), and injectors.
    I tried to use the stock MAF, but it blow away its hot wire at 1,5bar @ 7000rpm.
    I’m on test phase yet. In Lag department, I’m running 0,2bar @ 3200rpm, 0,5bar @ 3500 rpm, 1bar @ 3700rpm and 1,3bar @ 4000rpm (full boost). 1,2bar @ 7000rpm.
    Next week I will leave my car at the UNICHIP (A Porsche Dealer) center and do a new boost map (along with new timing and fuel maps). My intention is run 1,8bar @ 4000rpm (if its possible), 1,7bar@ 5000rpm, 1,6bar @6000rpm and 1,5bar @ 7000rpm. I expect to have ~410-430hp with this. I only run BR’s Podium gasoline (95 octanes IAD – 105RON) with 24% of alcohol).
    As soon as I have more pictures and videos I will post’em here.
    Regards,
    Mark
    Silver Audi RS2
  • Sidspud
    • 1223
    Now that is a nice photo!
    What is the black one nearest the camera?
    ex '93 Avant owner
    • Dutch_RsBlueS2
      • Sep 2003
      • 285
      Nice project m8 looks good and hopefully drives good to !
      Cheers Cees
      • Doug_RS2
        • 3847
        mark - how easy was it to get that MAF working? And what diameter is it?
        • KramRS2
          • 65
          It's a Bi-turbo S8.
          Try this:
          and then S8 Bi-trubo x RS6 ABT
          Silver Audi RS2
          • KramRS2
            • 65
            Doug,
            it was very very difficult to find out how to plug the MAF.
            The pins are different, and the impedance is different.
            I took information from the electric schematics from the RS2 and from the Porsche 928 to figure out how to plug them.
            Instead of charge you 100Euros for a thing that didn't work, like Thomas Schmalz did with Ricardo, I can share with you the circuit. Its very simple.
            "The 928 part is @ 86mm in inside diameter and there are no "cooling fins" in the intake barrel vs the stock & RS2 MAF's @ 72mm diameter tube. This works out to something like @ 9+square inches of available intake area vs. @ 6 square inches for thestock/RS2 version." I didn't measured it, so it comes from the Kruemmer list.
            Silver Audi RS2
            • Paulm
              • Dec 2003
              • 489
              i am very jealous
              S4 2.7 Twin Turbo, with a few mods
              • Doug_RS2
                • 3847
                Cheers Mark - I'm not in a hurry for it but I I would like to know how it was done.
                I think a few of us are going to be reaching the flow limit for the wire in the standard ABY MAF soon.
                • SteveH
                  • 4460
                  Doug, I'm looking into a supplier that produces a MAF from carbon fibre that is 10% wider than standard S2 MAF but uses the same internals. I'll send a picture when it gets here next week.
                  91 Modded 3B
                  14 A6 Avant Black Edition
