It was not covered with grease. You have got a lot of dust from somewhere, which adhered to anything, that was greasy. And in the engine bay, usually almost everything is...
Sau
My 3B-AAN 400 HP project
Apropos..... that Horn... is there from the first time i put the engine on that car....wy is still shiney and the rest no??
Has actualy 20k km.... hmmmm... what you think? Interesting...Leave a comment:
As aelred said you can use the dizzy for that function, iirc doug is doing this with the mrc600 as well.
In the picture above showing your engine bay what is the (possible bronze colour) circular object up by the brake fluid reservior? only thing I can think of is just something you've rested there?
Jesus...I should remove that before taking that picture..
Actualy..is the horn. No place to fit somwere else fast and without mud splashes around. Sounds like an old, tired cow... but working.
Hmmm .. i think i should remove that from the new engine bay.. dont you think?
Eagle eyes Acidburn!!
Thanks for reply!
This is the line to folow then... not bothering too much with the location off the hall signal.
Thanks!
Eugen
Sorry.. i cannot stop laughing!!
In the picture above showing your engine bay what is the (possible bronze colour) circular object up by the brake fluid reservior? only thing I can think of is just something you've rested there?Leave a comment:
The dizzy is ok to use as a hall effect sender, the ecu will do the actual advancing and retarding of the timing according to load. Once the reference signals have been received on start up the ecu will do the restLeave a comment:
I was reading about the hall senders and was thinking iff is any downside using the dizzy for the hall signal for my 3B to multicoil setup? I know that the first AAN had Dizzy for the hall signal but, except the space, there is something more involved in the changes made by Audi with the hall senzor mounting position?
Except the startup of the engine, hall signal has something to do with ignition advance during engine running, or for this the ecu use the CPS signal?
The idea is, I really need to move the hall sensor at the cam pulley or will be ok in the dizzy?
Thank You!
Regards!
EugenLeave a comment:
Some more with the trunk and some stuff whaiting to be put in...
Succeded to move the car in the new garage... i just whait to start strip her to bare metal...
The new home and some pictures with how she looks now!Leave a comment:
Some pictures with the panels.
I am soo happy!
Time for some update....
Just received the Sport Quattro body kit from Aelred... top service!!
Thank You Aelred.
I am still looking for an ECU ... because is verry dificult for me to find a good maper for Motronic near Romania...
Options are welcome!
Thank You!
About the 034K..i found out that is from the early 3B engines...so is ok.
About the other one..034A dont know...maibe somebody knows more..
Thanks!
Hello!
Tring to get the best parts for my engine, i have dismantled 2 3B engines...
Both have the crankshaft noted as 034K...In my list...this one is for 1B, MC engines, the right one for 3B is 034S...
This is right? This means that both off my 3B engines have wrong crank?
I have another crank i dont know from what car is it...Noted 034 A ???
Can you tell me from what engine this is?
What to do?
Thank You!
All the best!
Thanks!
I am verry curious to find out what hapend with that seal.
About the fuel....be verry carefull with romanian streets and high speeds.
I dont whant to see an S2 folow the R8.
Probably, for the remap i have to bring with me some Romaian fuel.... I am sure that Carrera rs from OMV in Romania is a medium one in UK.
Will see!
All the best!
Thought it was time I poked my nose in on this little project...
Looks like you have started finally..... any news on the piston wear yet? Did you source a new block, or get anything done?
I must say, that turbo does look especially nice....
Keep up the good work, but be careful how you fit the crankshaft seals, I have heard they are prone to falling out.....
I will bring you a bucket full of good petrol when I visit, so you will see how it works....
ChrisLeave a comment:
Dosin't exists the right word for that.....Fu........ed is close....The canal insight the block was stuck with oil residues and the rubbere tubes were gone...
The engine was running ok before....no oil consumtion also! Verry good engines!
Imagine that in that condition the compression was 11.5 bar at ALL cylinders...
Impressive, not?
I will have alot off work to do with that...Leave a comment:
