Audi Sport Quattro
  • G60Rallye
    • Dec 2006
    • 1321
    Bloody quick progress you are making! Where is the kit from? Are you going to be making your own sills or buying originals from Audi?
    • Tonks4x4
      • Nov 2005
      • 3062
      I have borrowed the kit till mine comes from KER. As far as the sills are conserned I think I will have an attempt at folding them myself this time....
      I have started another folder on facebook with more pics here.
      I can see now why people get to this stage and give up. The panels don't fit nice at all. and after very much thinking last night I think I will be cutting the wings rather than removing any more steel. You are supposed to remove all the outer steel from the 'B' pillar where the door shuts and replace it with the rear wing. but this is where the door striker is and shutting the door over time on this bit will make the rear wings crack I'm sure. so I will trim the wings down bond them on the inside of the 'B' pillar just inside the door shut and then make good on the outside with filler. It will make a much much nicer job. I will get some pics when I do it.
      Audi Nut!!!
      • garym
        • Jun 2005
        • 106
        keiths wheels
        keith murray used azev a 8x16 on his hillclimb car ,the compomotive replicas dont look right at all and they bend easily.ithink they might be genuine speedlines on the red car
        • Tonks4x4
          • Nov 2005
          • 3062
          Today's update. Got the 7A block back from being bored.... Decided to remove the core plugs and dipstick before sending the block to be acid dipped...
          Core plugs were a right PITA to remove along with the dipstick that decided to snap itself off at the base.
          Audi Nut!!!
          • Puglife
            • Jun 2006
            • 731
            whats the block been bored to? 83mm?
            I'm sending my 7a block off next week to be honed and dipped...
            Keep up the goodwork, coming along nicely
            Jay - pug_life85@hotmail.com
            1986 Audi UR quattro - WORK IN PROGRESS
            1981 VW Mk1 Golf - "20v Jim, but not as we know it!"
            • Tonks4x4
              • Nov 2005
              • 3062
              Yes the block has been bored to 83mm. A local engine center acid dipped the block over the weekend. I just need some info now on which are the best main bearings to use.. either 7A, S2, RS2... I have looked on the forum but can't find anything yet.
              I have got a set of core plugs on order will be here next week. I have acid etched the block tonight and given it a few coats of black paint. Progress on the project has stopped for parts for the time being.
              Audi Nut!!!
              • Flat on my back
                • Jan 2007
                • 2449
                Woz yu like...
                PM Aelred...
                Carlos.
                • Tonks4x4
                  • Nov 2005
                  • 3062
                  A quick piccy of bits... I should have coilover's tomorrow
                  Audi Nut!!!
                  • quattrostyle
                    • Oct 2006
                    • 6229
                    looking good
                    which coilovers did you choose?
                    • Tonks4x4
                      • Nov 2005
                      • 3062
                      Huy guys, I have not been able to post anything for several weeks because I have been waiting for the roof..... Well it's just landed.
                      My last series of posts was about which coilovers to go for as I had trouble with getting the KW ones. So I decided to go with quattronics CCK kit. After speaking to Corey he promised to have them completed in 2 weeks. As promised right on time I collected the set of coilovers with a set of subframe ally bushes and a set of promounts...
                      So tonight is the night I get my teeth stuck into the project again.....
                      There will be 9" grinders and welders all over the place....
                      Audi Nut!!!
                      • andy112
                        • Nov 2006
                        • 133
                        • Home: Poland Current: Canada
                        #41
                        Nice, do you mind if I ask how much the CCK kit sent you back?
                        • Tonks4x4
                          • Nov 2005
                          • 3062
                          CCK Kit £1145
                          What a nightmare to line up the roof..... You have to pretty much cut everything off the rear part of the shell... I will post some more pics on Friday...
                          Audi Nut!!!
                          • Tonks4x4
                            • Nov 2005
                            • 3062
                            Hi guys.... I need to ask a question.....
                            Does the original Sport quattro have a narrower rear seat base?
                            Replies would be appreciated sooner rather than later as I need to get on with welding...
                            Any photo's of the rear seat base and seat runners will also be a great help
                            Audi Nut!!!
                            • lagomike
                              • Nov 2006
                              • 112
                              • BRY
                                • 3755
                                #45
                                That would be a yes on the narrow question.
