12 months later......
  • S-Express
    • Nov 2006
    • 1133
    took my avant off the road last June, its been 12 months of hard slog (on and off!)
    But she's back with 12 months MOT, and it really does feel like new - no seriously, LIKE NEW! I've never driven a 15 year old car that felt so tight, precise, and lurvely to drive
    So the car was a pretty big mess underneath, bit is now like new - nothing has been left, its cost me £2758.05 (not that I'm counting or anything ) and probably 150 hrs labour but its worth every penny. so here's a list of the last 12 months:
    Oil change + filter change
    Both front wheel arches totally stripped, Bilt Hamber rust cured, primered and the POR15 top coat.
    Both front strut top mounts cleaned & greased
    New fuel filter fitted.
    Complete underneath rear-end stripped back to chassis for rust prep and refurb
    Rear drive shafts cleaned & painted
    Prop cleaned & painted
    New transmission mounts fitted
    New engine mounts fitted
    Oil pipe flanges on pump to turbo and oil cooler to sump pipes removed, cleaned, siliconed and re-fitted
    All under body panelling and associated bracketry etc sand blasted and powder coated
    All rear suspension parts sand blasted and powder coated
    Rear subframe sand blasted and powder coated
    Rear diff cleaned and both output shaft oil seals replaced (input seal not changed), diff lock boot replaced. magnet cleaned and re-fitted
    Handbrake adjustment mechanism cleaned & greased
    All 4 subframe mount bushes replaced
    Koni rear shocks fitted (set to softest setting)
    Rear top wishbone bushes replaced with Powerflex (3 sets per side)
    Both rear wheel bearings replaced
    Rust cure & repaint rear wheel arches (Bilt Hamber & POR15)
    Rust cure & repaint underneath from gearbox back to rear valence (Bilt Hamber & POR15)
    Rust cure & repaint whole rear apron (Bilt Hamber & POR15)
    Rust cure & repaint bottom corner of boot lid
    Fuel tank refitted with new filter and checked for leaks before bolting up tight - all ok
    Rear diff mount bushes replaced with Audi OEM
    Paint front grill matt black
    Rear bottom inner wishbone bushes replaced with Powerflex
    Rear bottom outer bushes replaced with new Audi OEM
    Both handbrake cables replaced
    New rear calipers fitted
    New rear pads & discs fitted
    New A8 314mm front discs & pads fitted
    Reconditioned RS2 Brembo 4 pot front calipers fitted
    All four hubs drilled & tapped. M6 disc retaining screws fitted.
    Remove side cills, de-rust and re-paint
    Diff oil change
    New Braided brake lines fitted all round
    Bleed brakes
    Gear box oil change
    Prop cv joints stripped, cleaned and re-greased
    Prop/diff aligned, prop centre bearing shimmed and aligned
    RARB drop links stripped cleaned and regreased
    Whiteline rarb + extra support brackets + poly bushes fitted
    New rear tie rods fitted
    Rust cure & repaint rear n/s door behind rubber moulding
    Rust cure & repaint large chip on bonnet and lower edge of front grill area
    Full geometry reset Balmuir garage
    and a few other bits too
  • mcandmar
    • Apr 2004
    • 5118
    Lovely job I will be thinking of these images while drilling out my camber bolt!
    Two questions, where did you get the ARB support brackets from? And got any pics of the upper a-arms with bushings installed?
    Cheers, Mark.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • S-Express
      • Nov 2006
      • 1133
      Cheers, Mark.
      Drill it out? I hope it does come out that easy, mine took more work than that
      • S-Express
        • Nov 2006
        • 1133
        my prop alignment soloution (as per Audi service literature)
        • S-Express
          • Nov 2006
          • 1133
          diff alignment using frikkin' laser beam......
          • S-Express
            • Nov 2006
            • 1133
            Cheers, Mark.
            you don't want to know put it this way, the guy i bought them off is not exactly liked on here!!!!!
            I took a risk, but it paid off for me (probably by pure luck!!)
            • Big Lee M
              • 2571
              How much then????? If you don't mind me asking? Nice work there. I bet you felt like giving up a few times.
              Just some finishing touches to do now
              • Acidburn
                • 13459
                Looking good there, whats next on the list just enjoying it or anything else?
                • PeteRR
                  • 1326
                  Top job Alex! Looks good to go the next 15+ years.
                  • s2driveruk
                    • 12696
                    looking great and should be sound for years
                    1992 3b S2 Coupe
                    • S-Express
                      • Nov 2006
                      • 1133
                      Thanks boys - should be sweet for years to come..................
                      • S-Express
                        • Nov 2006
                        • 1133
                        for a year or so me thinks!!!
                        Then I'll have to bow to the pressure to get more power....
                        • S-Express
                          • Nov 2006
                          • 1133
                          £2.7k, lots of blood, sweat and tears!
                          • kingfishers2
                            • Feb 2007
                            • 756
                            Excellent work im part way through doing this to mine, where did you get those stands from in the pictures? i need to raise my chasis up for better access.
                            Chears alex
                            • Ducky
                              • May 2006
                              • 636
                              Wicked job there fella....if I had the time I'd do it myself, but couldn't bear the car to be off the road for so long!
