Edit
My Audi S2 600Hp+ project 56k warning
This topic is closed.
So this is the car from the start, I will do it in date order as much as i can.
The car
Photoshop black wheels
Front
Side
Wheel
Rear quater
Front arch
Side shot
Engine bay some time ago
Chef -
Orginal engine and plan
First mock up of a sensible spec
Loom to go in
Engine work
FW
Furans
Catch tank set up
ChefComment
WGFV
Rods and pistons
Bores
An Fittings for oil cooler LARGE
Crank shaft
More block
Nuke fuel rail
External pumps
83mm torque plate for custom gaskets
ChefComment
Engine build
Converted 3B head with send boss welded into place and machine down
Got my head on
test fit oil cooler and lines
Repo art work
Next the engine bay was sanded and primed. I sprayed it at home, had to redo it as the paint had a reaction with some thing.
ChefComment
Refreshed gear box
Brakes or porn?
Fronts
Vs mono's
Fitted
Braied connector
Very tight to the face of the rim
The body of the car is good so it took very little work and now looks a bit like this
Simples... solution
Vent for petrol tank as the carbon canister has been erased
034 engine mounts
ChefComment
Diff
Solid diff mount thanks to pete after my first one went a bit wrong!
Catch tank set up with coil mount on the strut brace
Battery was moved to the rear
And about a month ago i got to time the engine up.ChefComment
Stunning work love the attention to detail, would hate to think how much all those braided lines and fittings cost! god i miss my engine...Comment
