David 3b S2 Conversion To Rs2 Coupe Project
  • david
    • Oct 2008
    • 1268
    my 3b s2 is now ready for major Rs2 conversion.
    this is what i have so far
    [please let know if i'm missing anything to complete this conversion]
    RS2 ENGINE
    OIL COOLER
    RS2 INTERCOOLER[still on the lookout for xmember]
    42lbs/hr (465cc/min) at 43.5psi GREEN TOP INJECTORS
    RS2 WIRING LOOM
    RS2 ECU
    STILL ON THE LOOKOUT FOR RS2 AIR BOX
    RS2 REPLICA FRONT BUMPER
    3" DOWNPIPE[might just go full 3" anyway
    BIG REDS GT3 FRONT CALIPERS
    will update if anything else turns up.
    [SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
    RS2 VOLCANO BLACK] soon to be broken to bits
  • Rusty
    • 18953
    Might be worth getting an ABY/ADU fan for the rad and go full Samco water and air hoses
    Also, get some stronger rods in there so you can extract the full potential from the RS2 turbo.
    Should be very nice when all done
    • GazzaG60
      • 4133
      what you got airbox wise. dont like the look of the filter.
      id go for 993tt discs and bells and brackets to suit.
      • david
        • Oct 2008
        • 1268
        i thought about getting the rods in there,but my project money is fast running out.still might do that cos i will be after BIG hp in the near future.
        • david
          • Oct 2008
          • 1268
          where best to get that then?
          • david
            • Oct 2008
            • 1268
            what do you think about Aronmatic rods?
              With RS2 ecu you can run the MRC 1.9 high boost generic map, HIGHLY recommend doing that although you aren't using RS2 injectors which may mean your going to need a full remap or a S2central homefry maybe tweaked to suit.
              You don't need new rods if it's mapped less aggressively low down or run on the stock map. To get the full potential from the turbo with low grunt it does need new rods for safety.
              You don't need an RS2 x-member the S2 one can be modded plenty of threads showing how it's done.
              Are you converting to 6 speed geatbox? the 5 speeds not going to like the RS2 torque
                Same as Scat but better weighted.
                They are all from the same design very good for budget builds
                • david
                  • Oct 2008
                  • 1268
                  cheers jamo
                  • Rusty
                    • 18953
                    I was planning on going with rods from Aron before finances took a dive ealier in the year. This is still the route I'll take if I build a proper engine.
                    • david
                      • Oct 2008
                      • 1268
                      yeah i know,but that's the way to go if your after proper engine.
                      Aron still waiting for me to pay for my set
                      • david
                        • Oct 2008
                        • 1268
                        yeah i know about the s2 xmember mod,just looking for easy option
                        i've got 6 speed gearbox,but as they say if it aint broke dont fix it
                          It will be broke soon enough ask Audiman
                          I think a few members have them in higher powered cars, you'd have to search around
                          • david
                            • Oct 2008
                            • 1268
                            you will be first to know
                            no harm in finding out
                            • GazzaG60
                              • 4133
                              id go with rods. i got scats. no probs so far. like many say most rods look about the same but engraved. cost me 300 dollars for a set.
                              weight wise i had mine matched. its best to do either way for the 50 quid or so. i like the idea of less worry, more potential so id fit rods.
                              brake wise speak to bambridge i think it is now. mine were from quattronics a couple of years back. discs are from ECP. bout 115 each.
                              potentially i would also look at the value of the rs2 IC, inlet and hoses against the cost of a wagner inlet, ic and xmember. maybe you can get good money for your rs2 bits.
                              get some arp head studs too
