Nissan 200sx S13 with 2.2T 20v audi engine
  • Billman
    • 4129
    Did you checked the primary trigger Degrees before TDC with a timing light?
    Go Holset or Go RS4
    • Bruno
      • Jul 2007
      • 58
      • Country: Norway
      A Volvo diesel gearbox.
      What is the teoretical top speed?
      • button
        • Dec 2007
        • 99
        • Country: Poland
        Billman
        no
        Couple of engine from me runs on this setup and I don't change it.
        Bruno
        Teoretical and practical top speed on 285/30R18 tires with rev set on 7200rpm is 281km/h
        Audi 90 quattro '88 4.2V8 on VEMS
        Audi S4 C4 Avant 2.2T '92 @ 2,5TDI
        • Hortex51
          • Dec 2009
          • 11
          • Home: Poland Current: Norway
          Hi guys!
          After a long and painful tuning experience we had with mounting the 01E gearbox, pushing the sh***t out of the car, I've decided to go for 83mm pistons.
          Now...
          As far as I can see, all MLS gaskets are up to 82,5mm. Could you please tell me if OEM Victor Reinz will be sufficient for my bore? Any experience?
          Thanks!!
          • Hortex51
            • Dec 2009
            • 11
            #20
            Car is finally finished.
            Couple of clips:
            http://www.youtube.com/watch?v=5fL-w4yA ... re=related
            FYI, 2nd gear ends at 120 kmh
            • djh
              • Jun 2011
              • 1622
              • Home: United States Current: United Kingdom
              #21
              First link worked fine and car sounds/looks brilliant, second link don't work unfortunately.
              • Billman
                • 4129
                #22
                nice, did you make another dyno run?
                Go Holset or Go RS4
                • Hortex51
                  • Dec 2009
                  • 11
                  #23
                  I know.. second link doesn't work, but it's run #2 - don't know how to edit.
                  Nope, no dyno run yet. But this time we decided to run 1,8 bar all the way to cut off. This way instead of burning rubber, car accelerates... fast
                  • terrybullwon
                    • Mar 2006
                    • 8782
                    Which gasket did you use in the end?
                    Chef
                    • Hortex51
                      • Dec 2009
                      • 11
                      #25
                      We used an OEM rs2/3b gasket - same part number.
                      However, we used 82,5mm pistons - I mixed the 83mm with our other project... But the gasket works, though it says it's only up to 82mm.
                      • dspl1236
                        • Feb 2008
                        • 242
                        very nice sir
                        '91 Pearl 3.6 V8 CQ - building
                        '13.5 Jetta GLI - toy
                        '15 Subaru Imprezzzza - work daily
                        hausofdub.com
                        • Hortex51
                          • Dec 2009
                          • 11
                          #27
                          Some latest info.
                          Weight with full tank 1280kg.
                          I need better camshafts, quick
                          Cheers!
                          • Billman
                            • 4129
                            #28
                            niice, did you used the old timing map?
                            Go Holset or Go RS4
                            • Hortex51
                              • Dec 2009
                              • 11
                              #29
                              It was modified a bit. We had to deduct lots of fuel at the top, when we installed the swirl pot. And boost is lower, 1,85 bar.
                              • Hortex51
                                • Dec 2009
                                • 11
                                #30
                                Couple of latest pictures...
                                Shot at 2011-09-15
                                Shot at 2011-09-15
                                Shot at 2011-09-15
                                Shot at 2011-09-15
                                Shot at 2011-09-15
                                Shot at 2011-09-15
                                Shot at 2011-09-15
                                Shot at 2011-09-15
                                Shot at 2011-09-15
                                Shot at 2011-09-15
                                Shot at 2011-09-15
                                Shot at 2011-09-15
                                Shot at 2011-09-15
                                Shot at 2011-09-15
