Epic! Keep it up Dave!
Audi S1 build thread.
Incredible
2000 B5 A4 Quattro Sport ~ 2.0 20V GT30R ~ Gone
1993 S2 ABY Coupe ~ Gone
1989 2.2E Coupe ~ GoneComment
Is that the specs that schanche specified or did you go with your own settings ?
This car is going to be awesome. Can't wait to see it doneComment
Thanks for the coments guys
Oil water and Fuel hoses are all run. The two dry brake fittings are for a engine pre heater so I can pre warm the engine to 65degs before even starting it.Comment
Fuel Pump is rated to 2000HP worth of fuel (needed as it will be running on Methanol) also the filter on the left is good for normal fuel but a stainless steel unit is needed for methanol use.Comment
i like mate whats the bhp on the engine (from the flywheel) ?
the suzuki escudo which im building (currently on the planning stages
)sigpicComment
Hoping for around 700hp to 800hp
All the hoses are run inside the carComment
Front suspension and brakes are all done, still need to have a measure up for the drive shafts but! not sure who is going to make those yet? Liner Pots will be wired to the MoTeC Dash to measure what’s going on. I also have a infra red brake temp sensors to be fitted also so I can make sure the brake balance is set correct.
Mega build, not sure if its been mentioned but who built the chassis ?
If I ever do a hill climb I hope I'm not against you lolComment
