Hey guys! After lurking for some time I thought I would finally post up my project!
For those who don't know me, my name is Hans and I work at a shop in Minneapolis, Minnesota called Imola Motorsports.
It all started with a crazy cheap URS6 purchase at an auction:
The S6 had many issues, more than I felt like sorting through as I was well aware that it would add up quick and would not be worth fixing. There were a bunch of aftermarket bits on the car like an Apikol coilpack conversion, Samco hoses and MTM stage 1+ ECU that I could put to good use in swapping the motor into a coupe making the idea that much more appealing. The big drawback of the situation was that the motor had spun rod bearings and was knocking pretty badly.
Even after receiving several offers from people who wanted to buy the car as a whole I decided to part it and start building the motor.
Initial disassembly revealed a considerably clean top end for 163k miles.
Bare block ready for the machine shop
Hot tanked, honed, decked and painted
The goodies: Balanced and polished crank, 034 coated main and rod bearings, Scat rods and cleaned AAN pistons also balanced.
Center main bearing needs the tab filed down (sorry for the terrible picture)
Installed crank and mains.
...and onto some head work...
New valve seal vs. old.
Lappin' da valves
Overall it took me about 10 hours straight to pull all the valves out, clean them on the wire wheel, clean the head, meticulously lap the valves, install new valve seals, and reassemble the head. This was my first time doing this and it wasn't in my budget to bring it to a machine shop but I plan on building a head in the future with springs, retainers, etc.
Lapped and cleaned ready for install
...Just waiting to transfer some 7A cams in.
Lappin' da valves
