+400hp ?
  • Tommy200rs
    • 285
    #61
    could you reveal us then what happens after 5 volts info ?
    • Mihnea
      • 1288
      #62
      Not much, same as with a 200/250/300/whatever kPa MAP sensor exceeds 4.8v output signal. If the chip is programmed right, not much will happen.
      The problem with 5.2v output range is different, part throttle/idle will be messed up and will require remapping, but WOT will definitely be OK.
      This sort of mods are not necessary up to 450-480HP IMHO/IME, and all these power ranges need a real-time emulator to be tuned correctly. Too many fudge factors involved in tuning such cars past 400HP without real-time access and trace functions.
      Mihnea
      www.MRCTuning.com
      info@MRCTuning.com
      Workshop Directions
      • PekkaS
        • May 2004
        • 81
        #63
        Hmm.... I won´t get over 480hp with current turbo. So I quess I´ll flip coin about doing resistors or not.
        • audiman
          • 4827
          I run 480 on a stock 3B MAF. Wire is still hangin in there!!
          Tom C - www.rcmr.co.uk
          Audi UR Quattro
          Audi 100 C3 2.0 5 cyl 115ps
          Audi B5 RS4 645ps 911nm
          • Tommy200rs
            • 285
            #65
            rebirth has happened and the engine started again.
            • PekkaS
              • May 2004
              • 81
              #66
              here we go...
              • PekkaS
                • May 2004
                • 81
                #67
                ready to rock.
                • PekkaS
                  • May 2004
                  • 81
                  #68
                  Some tuning, Mr Karala and Tommy.
                  • PekkaS
                    • May 2004
                    • 81
                    #69
                    This is terrible to watch, if it´s your car howling on rollers..
                    • PekkaS
                      • May 2004
                      • 81
                      #70
                      It gave only 435hp, should go near 500hp with bigger injectors. We´ll see.... :mischeif:
                      • PekkaS
                        • May 2004
                        • 81
                        #71
                        Oh, and that 435hp was gained at 1,4bar boost.
                        • audiman
                          • 4827
                          Cool, thats great work!! What a result. You must be really happy with it
                          Audi UR Quattro
                          • PekkaS
                            • May 2004
                            • 81
                            #73
                            Thank you. Yes, I´m very pleased after four months of mk1 VW golf... Only thing that pisses me off is that friend of mine using bigger injectors got 458hp with GT2871R on RS2. Here´s some poor quality video.
                            • Mihnea
                              • 1288
                              #74
                              Sounds really good BTW, congrats to you and to Mika!!!
                              What injectors are you running? RS2?
                              www.MRCTuning.com
                              info@MRCTuning.com
                              Workshop Directions
                              • PekkaS
                                • May 2004
                                • 81
                                #75
                                Yes, RS2. Btw, when you come over here you´ll have some fine-tuning to do with my car.
