+400hp ?
  • Mihnea
    • 1288
    #76
    If Mika is not pis$$ed off with that, it'll be my pleasure
    Originally posted by PekkaS
    Yes, RS2. Btw, when you come over here you´ll have some fine-tuning to do with my car.
    www.MRCTuning.com
    info@MRCTuning.com
    Workshop Directions
    • ottawa coupe
      • 856
      jeebus!!!!! that plot is pretty nuts!! the only other plot i've seen that was remotly close to as vertical as that was a mk1 jetta on nitrous! (a 60 or 70 hp lightswitch) i'm sure it's pretty fun when the boost hits
      congrats and good luck getting the 500
      1993 UrS4...aka the rocket powered living room
      • repo
        • Dec 2004
        • 893
        Mika tuned 3 20v 5'ers that day.
        RS2 with gt2871R: 458hp/519Nm, (513Nm @ 3700rpm) with lots of surging problems at spoolup.
        Pekka's S2
        And finally one bone stock 3b with Holset H1 54in/65ex: 450hp/537Nm with 1,6bar boost.
        • Tommy200rs
          • 285
          #79
          The second 20v has nice 300NM at ~2700 RPM And then the powerband climbs up to 7000 RPM. - nice every day driving power ..... the 3B was stock except maf, injectors, map and fpr + the needed SW mods from Mika
          • audiman
            • 4827
            Stock exhaust?? I dont think so surely
            Tom C - www.rcmr.co.uk
            Audi UR Quattro
            Audi 100 C3 2.0 5 cyl 115ps
            Audi B5 RS4 645ps 911nm
            • repo
              • Dec 2004
              • 893
              ENGINE was stock, IC and exhaust replaced, sorry for inaccurate impression.
              • +500hp
                • Dec 2004
                • 51
                #82
                Pekka's S2
                What did you mean with "lots of surging problems at spoolup"?
                What boost (RS2-Gt2871R) is driving?
                • Billman
                  • 4129
                  #83
                  Do tou have any infos on the Holset charger? Any power diagramm?
                  Greetings
                  Go Holset or Go RS4
                  • Markus
                    • 184
                    Great work Pekka, Repo and Tommy! Also surprised and impressed seeing the GT2871R make that much power.
                    Markus
                    '94 Kristallsilber-metallic S2 Avant.
                    • TURBOKONGEN
                      • Sep 2004
                      • 4
                      #85
                      Reply :
                      Those are very impressive numbers for that turbo . I really did not think this turbo could give this sort of power .
                      What boost was the engine running at ? Was regular street petrol used ?
                      Size of injectors ?
                      • TURBOKONGEN
                        • Sep 2004
                        • 4
                        #86
                        I reckon this is with the bigger .86ar turbine housing on the GT2871R .
                        • kalsket
                          • Sep 2004
                          • 78
                          I can see that people have been quite interested in my setup, so here it is:
                          HW:
                          ADU-std: pistons, bearings, in-cam, valves, compression, in-manifold, injectors and fuel pump
                          AAN-ex.cam (in order to compensate too freely flowing ex-side head)
                          Verdi rods
                          Head done by Kansiset, intake max flow 312 Hp
                          Tube header and downpipe by Pro-mo
                          Turbo GT2871R, (turbine housing 0,64 A/R) with internal wastegate
                          Boost control std. Motronic
                          Exhaust 3" turbo back, no cats
                          Here you can see used boost pressures on different revs
                          We also tried 2.0 bar max boost but it gave nothing compared to 1.7 bar.
                          It will be interested to see what changes Mihnea would do to SW. After all Mika had very little to ad to Tommys work. Some leaning has still to be done on cruising loads, AFR<14 at the moment.
                          4F 2006 avant 3.0tdi quattro
                          4B 2002 S6 avant quattro
                          typ85 sedan quattro with "minor" changes
                          • repo
                            • Dec 2004
                            • 893
                            This restrictive action was made du to the fact of bad port job made by previous engine workshop.
                            I saw Mihnea mentioning surging probs of Garet ballistic turbos in some thread, and appears that he is right (as usual?)
                            Solution for this feature (rather than a bug) would be enhancing air consumption of the base engine at 3000-4000rpm area; cam timing, or different cams maybe.
                            the key to reasonably big hp figure is good cfm/hp ratio, which is close to 1.47 in this particular engine. As Teppo mentioned, we gained one hp with 2bar boost, indicating total run out of compressor flow. You can also see this from the compressor map.
                            Exhaust backpressure was some 2.2bar at +7000rpm.
                            I'll post holset - 3b-setup dyno plots when I get one. This setup was intentionally made to rock at high rpm range, due to stock internals, and purpose of the car (circuit racer).
                            • Mihnea
                              • 1288
                              #89
                              Thanks for the details and thanks to repo for the explanation for the AAN exhaust cam, which first sounded like a brain-fart upgrade to me
                              2.2 Bar exhaust back-pressure at 7000 RPM definitely sounds very good with 1.7 Bar.
                              Mihnea
                              www.MRCTuning.com
                              info@MRCTuning.com
                              Workshop Directions
                              • kalsket
                                • Sep 2004
                                • 78
                                exhaust temp on dyno 850 C
