that 20vt 200....
  • dspl1236
    • Feb 2008
    • 242
    was almost ready......
    .....hmm standalone
    3b to dta
    '91 Pearl 3.6 V8 CQ - building
    '13.5 Jetta GLI - toy
    '15 Subaru Imprezzzza - work daily
    hausofdub.com
    • dspl1236
      • Feb 2008
      • 242
      coilpacks!
      hausofdub.com
      • dspl1236
        • Feb 2008
        • 242
        done. extras setup...narrow and wide o2's, shift cut, antilag/launch, o2 disable, log switch, 2nd map, and a shift light. still have a few optional options left...4 wheel speed sensors, traction, wet/dry, nitrous, and still a few extra inputs and outputs...
        hausofdub.com
        • campbellWS
          • Oct 2010
          • 446
          200 20vt
          car envy!
          • Kieron20V
            • Mar 2008
            • 1505
            #20
            Is this the DTA from the v8?
            1994 URS4 Avant RS2+
            • dspl1236
              • Feb 2008
              • 242
              yup. i think it better suited for the I5 than the n/a v8....and lets face it... its a v8 and almost any standalone will do well on it. all i had to do was buy 5 2.5 coilpacks and a crank trigger. i realy want vems...but i still has more features other then plug and play
              DTA works will all the sensors with my convert harness. scored a new Autotech adjustable cam gear from a buddy since it no longer can be used in his 20th gti 5xxhp 1.8t project. installed the 034 60-2 pulley and vr trigger bracket as well
              options setup: narrow band o2, wideband o2, o2 on/off switch, 1/2 map switch, log on/off switch, antilag/launch button, f/r 2wheel speed, traction on/off.
              was off one tooth on timing....did my 1/4 drive extension trick to jump the timing one tooth.....the belt stretched and tore...mental note....trick can only be done via hydraulic tensioners only
              hausofdub.com
              • dspl1236
                • Feb 2008
                • 242
                hausofdub.com
                • dspl1236
                  • Feb 2008
                  • 242
                  3bar map is here....that was the last item for the ecu.
                  hausofdub.com
                  • dspl1236
                    • Feb 2008
                    • 242
                    wideband is here and took the liberty to enable the onboard accelerometers
                    hausofdub.com
                    • tajgreidotu
                      • May 2008
                      • 324
                      • Country: Spain
                      #25
                      Originally posted by dspl1236
                      coilpacks!
                      Are they stock coilpacks or 1.8t or ... ?
                      Awesome car!
                      • dspl1236
                        • Feb 2008
                        • 242
                        Awesome car!
                        thank you. these are the vw 2.5 coils with a little bit of trimming. i have a set of 2.0tfsi coils on my 32v 3.6 v8 and tried to get those to fit my 3b ... no go. i think the 1.8t ones will fit the aan......but the new tall coilpacks have a higher output
                        1.8t guys are using the newer tall coils on big turbos are gapping them up to .035" and .04" from the .028" and .026" that is normally use for chipped and big turbo. smoother idle as well.
                        only know this because i had the o so powerful 1.8t
                        hausofdub.com
                        • tajgreidotu
                          • May 2008
                          • 324
                          • Country: Spain
                          #27
                          Im asking you this because Im going to use stock coilpacks with 3b head cover and Im sure ill have to trim them.....but dont know how much!
                          Cheers!
                          • dspl1236
                            • Feb 2008
                            • 242
                            Cheers!
                            ill take a photo of my trimming for you
                            hausofdub.com
                            • bikerjim
                              • Feb 2008
                              • 1028
                              Awsome project, watching closely
                              • rs200
                                • May 2009
                                • 1398
                                • Home: Croatia
                                #30
                                me too !!!!
