so after all my issues of puting car back together new clutch starter motor cam belt and gubins.
only for the the starter to spin up and the crank not turn. i have finally been able to get my unit half painted and have pulled the engine out again to find the ring gear not cracked just has slipped of the flywheel.
so can some one please post a picture of a 3b fly wheel, as there is a recess two teeth wide on the back of the starter motor ring gear and due to the two censors for the timing pin and i assume the recess in the ring gear. i need to press this back on in the right place.
cheers also due to my inexperience i pulled the flywheel of without marking up so i need the alignment for timing pin and tdc to put back on
jack of all trades
jack of all trades
