Audi S2 Coupé -91 - Some fix & Tuning!
  • Niklas_S2
    replied
    Originally posted by mushasho!
    Any of these would get you there with ease:
    Forced Performance HTA3582r, HTA3586r, PTE6262, GTX3582r, Super40, Comp6262, ect.
    You can get better spool with a smaller 58mm wheel but would most likely need to run above 2.4bar, need cams and porting.
    Thanks alot! I´ve been looking at PTE6262 and GTX3582r and they seems to be solving my HP...
    Yeah, i thought that too, but i´ll be running most likely at 2,4-2,5bar.
    Here is my setup:
    3B-engine / 2,2L
    Engine setup:
    Block
    #H-Beam Rods
    #Balanced (pistons, rods, crankshaft, flywheel, clutch and crankshaft pulley)
    #Cylinder block is Milled and Honed
    #ARP-bolts for flywheel, crankshaft, rods and cylinderhead
    #Homemade surge protection in the oil pan
    #Steel gear on the crankshaft
    #ACL Bearings
    #Bushings in Delrin to the engine and gearbox
    #New waterpump
    Cylinderhead
    #Ported
    #Milled Valves and seats
    #New valve guides on exhaust side
    #Milled to the deck surface
    #New valve seals
    #Stiffer valve springs
    #7A Cams
    #Tommi´s Billet adjustable cam gear
    #New timing chain
    Exhaust
    #Turbo (Not decided yet) (T3)
    #Cp-service exhaust manifold
    #Stainless 3" with 3,5" downpipe
    #Turbosmart 45mm WG
    #Turbosmart 50mm Blow off valve
    Intake
    #Home made intake of aluminum with fullradie hoppers
    #Original throttle
    Fuel
    #Braided fuel lines AN8
    #E85
    #Bosch 1700cc fuel injectors
    #Aeromotive BTR
    #Fuelpumps - 1 Bosch 040 in tank and 2 Bosch 044 after catchtank
    Gearbox/Clutch
    #Sachs 707 push plate
    #Sachs 4-pad torsion sinter-pad
    Ignition
    #Megasquirt v3x
    #VAG 60-2 trigger at crankshaft from Audi A2
    #VAG 115R-coils
    #Hallsensor from ABY/AAN
  • rynaqui
    replied
    Same, very very clean looks to be running big numbers soon!
    replied
    First time I've seen this project - wow
  • mushasho!
    replied
    Originally posted by Niklas_S2
    E85 "Ethanol"
    Sent from my HTC One using Tapatalk
  • Niklas_S2
    replied
    Depends on what fuel you're planning on...
    E85 "Ethanol"
  • mushasho!
    replied
    Have not decided what turbocharger I am going to run with.
    I run with T3, and want to pull 6-700hp at the engine...
    Any suggestions?
  • Niklas_S2
    replied
    Exhaust
    Any suggestions?
  • Niklas_S2
    replied
    Exhaust!
  • Niklas_S2
    replied
    Thanks!
    Originally posted by anthonys2
    Enjoyed looking through this thread and what a stunning S2 absolutely amazing great job with all the engine bits and what a stunning looking car well done mate!
    Thanks man!
    Spent a couple of hours this weekend in the garage...
    The fuelpumps placed in the hidden compartment at the back of the car.
    The only things visible...
    And a pic on the enginebay.. Seems very empty on the exhaust-side Only for the car inspection
  • anthonys2
    replied
  • Niklas_S2
    replied
    Time for an update!
    Mounted the intercooler last week!
  • -coupe-
    replied
    Awesome!
  • Niklas_S2
    replied
    Are you on Instagram?
    That is correct... Same username as here.
  • mushasho!
    replied
  • Niklas_S2
    replied
    With the front spoiler on... It is approaching
