Audi S2 Coupé -91 - Some fix & Tuning!
  • Niklas_S2
    replied
    Last friday I got my new Turbo (TB60-01) from www.turbobandit.com
    Welded the WG-flange (V-band) on to the exhaust manifold.
    Original kkk K24 in compare.
    Might turn out well!
    Started to build a new downpipe...
    Finished it last night. Not fully welded yet!
  • Niklas_S2
    replied
    The car was fired up 7 July and seems to run very well
    I have done tree oilchanges in about 100kilometres, and the car is soon ready for the Swedish car-inspection
  • Niklas_S2
    replied
    Originally posted by prj
    Which will do absolutely nothing about this problem, unless you have a lambda on each runner.
    They usually fail one at a time, so lambda might look more or less ok, because the readings are bad only on one cylinder the average that the lambda probe is seeing is still decent. And to blow the engine you only need one cylinder to be lean.
    For example, 4 cylinders on 12 AFR and one cylinder on 15 AFR. The lambda will show 12.6 afr, which is only 5% difference from target. But actually one cylinder has 25% difference.
    You´re right of course! But i´ve got a 2.5L dieselengine in spare, so it would be a reason to build another engine
  • Niklas_S2
    replied
    Out of curiosity, what is the part number on the injectors? There do not exist EV14 1700cc injectors from Bosch that are compatible with E85 as far as I know, anything bigger than about 1000cc are CNG injectors and Bosch does not recommend using them with E85.
    Of course it is possible your injectors are custom modified from a smaller E85 injector.
    I am saying this just in case, from experience. Plenty engines gone the way of the dodo due to this mistake.
    I think it is "110R-000120 NGI2"
    Okay, that i did not know! It says that they are compatible to E85 where i bought them and that they definately should not be driven on petrol 95,96 or 99 octane.
    I´m thankful that you telling me this!
  • prj
    replied
    Originally posted by Niklas_S2
    My ECU will be adjusted so that the engine will stop working if the lambda outside the limits.
  • prj
    replied
    The injectors are compatible with E85 according to spec.
  • Niklas_S2
    replied
    After reading your spec list there is one thing I would like to say.
    I am pretty sure the Bosch 1700cc injectors you want to fit are not compatible with E85.
    They are natural gas injectors, and if you leave E85 in the fuel rail and the car standing for some time, they eventually will seize one at a time. And if you do not notice this in time, you will melt your engine.
    But if you dismount them you will have to place them in a bath of e85 or in a bag with vacuum.
    Perhaps i will change them later but they will due for a startup and a little run with my original k24
    Thanks for the warning anyway
  • prj
    replied
  • Niklas_S2
    replied
    Random pics from this weekend!
  • Niklas_S2
    replied
    Today i finished the wiring of the ECU and tested the in/outputs
    Hope to startup next weekend or something like that
  • Niklas_S2
    replied
    Originally posted by quattro-nick
    nice wheels on your car,i like them a lot!
    You've done a great job on your car so far, keep us posted!
    They are nice, yeah I sold them a few years ago, but I am going to buy 18" instead of 19" of the same type of rims
    Thanks alot!
  • quattro-nick
    replied
  • Niklas_S2
    replied
    Hope this will due for ventilation of the valve cover.
    Drilled a hole and welded a bit by the hole.
    Also welded a tiny bit of cover on the inside.
    Will put a 90 degree tube connector on the side against the firewall pointing at the gearbox.
  • Niklas_S2
    replied
    Been in the garage this weekend
    Oilcooler in place
    Cut my intake to fix some fitment
    The fuelrailen will be "build in", and will give the fuelinjectors a better angle
    Fixing some vent for the 7A-valve cover. Will place a 90degree connection in the back of the cover so it will be hidden. Then a hose to my oil catchtank.
    Mounted the front bumper last night.
    //Niklas
  • Niklas_S2
    replied
    Originally posted by Error404
    First time I've seen this project - wow
    Originally posted by rynaqui
    Same, very very clean looks to be running big numbers soon!
    Hehe, thanks!
