URquattro - S8 4.2l AHC
I had a problem to start the engine after all and trying to figure it out what's the problem. The main reason was broken crankshaft position sensor. Actually, I didn't measure position hole correctly, so the flywheel was grinding sensor and this is the result
I found replacement sensor and put one washer between sensor and tranny, so now there is enough space between flywheel and sensor
In the meantine I bought new spark plugs.
Because the car is working like on 6 cylinders, I will convert ignition coils for a brand new Beru ZSE033 coils. It is much cheaper solution than buying new S8 coils, boots and ignition modules.
http://www.ebay.com/itm/400280564194...84.m1423.l2649Audi URquattro 4.2l, Dodge Charger 7.3l, Golf 4 TDI 4Motion
no replacement for displacement
common issue with sensor placement and angle?
nice job mate
btw ... no downpipes
https://www.youtube.com/watch?v=5vlQITf6dx4
