Might be an idea to check crankshaft journals prior to buying bearings just incase you need a crank re-grind, as was in my case. Mine was sitting for a while and formed little corrosion pits in one of the journals, so I had to buy another set of undersized bearings
Master Power is made in Brazil and has nothing to do with cheep China turbo´s.
Master Power is a upcoming brand and is wary good quality.
My friend is agent for Europe so if anyone like to try this turbo let me know.
A new web page is under construction but her is a link to the old one http://powerpage.dk/node/195
Data.
Info MPR5449
600hp
Compressor Wheel: 54x77mm
Compressor Wheel Type: 7/7 blades
Compressor Wheel Materials: BILLET Forged Aluminum
Compressor Housing Area: 13cm² - ANTISURGE
Bearing - New MP Racing 360 degree trust bearing - watercooled
Turbine Wheel 49,5/64mm
Turbine Housing: 12 options, valgt A/R 0,63 T3
