Aaron: 847 AWHP.
  • speeding-g60
    • Aug 2008
    • 1186
    Aaron: 847 AWHP.
    so, i decided to dyno without tuning just to see where we left this season, for power. and it did pretty good i must say.
    847 AWHP. 611 WTQ. and lots of tire slip on the rollers. 46+ psi, still with a small port head too. and still semi conservative with the timing. we have it mapped to limit boost @ 390 kpa but it finds 421-422 kpa on its own so whatever. it gets the whole 390kpa in second gear on the track. it works.
    and i have pulled the plug on this season. work and weather are getting non-compliant, we only have a couple weeks left anyhow, and i figure why not. i wanted to hit it ONE MORE TIME with the sequential shifter now being back, but alas i just decided to skip it. i could quite possibly have gotten it down some more, but leaving off with 167 mph trap speed and still 9.41 is good enough.
    my tuner has a car he works with, and they are having a hard time getting cams from CAT in a timely fashion. they have a BIG money race in a couple weeks, and another one in a month after. so, i pulled the motor apart and pulled the cams for them. team play!
    one of the bigger changes i plan to do is an 8.8" live axle rear end and a 4-link setup. still Quattro (for now) and the ability to switch to RWD only is much easier at that point
    I presume the 8.8" live axle/rear diff is running 4.11:1 gearing to match the 01E front diff??
    • speeding-g60
      • Aug 2008
      • 1186
      yep.
        Some big numbers and fast passes Aaron, you must be pretty pleased with the car right now?
        • GazzaG60
          • 4133
          good stuff.
          shows the 4 pot can do it. as can you.
          • A1QSHIP
            • Aug 2004
            • 975
            Those boost figures are running in to the area of the original F1 turbo motors. Congratulations are due to you sir!
            Chris
            "Nulla tenaci invia est via"
            • speeding-g60
              • Aug 2008
              • 1186
              so, a little update.... a sad one. and things progressed as far as the live axle back half. it was too much work to take this car backwards, so i am just building an entirely new car.
              this motor served me very well. but it is dead. i drained it for the winter, but did not pull the plug for the oem turbo coolant feed (i use an oil only turbo) and the block froze and shattered cyl #2. it still had a little water in there i guess. oh well.
              building a new block (i dont want to use the new race motor that is going into the tube chassis car) so at least i get to tighten things up a little and i may just push it harder now, that it is all fresh and lovely. will be nice to spit out 900+ awhp i think, although i will not be running that anymore. i am turning back the boost to around 35-36 psi, using a stock RS2 gearbox, and gonna have fun while i build the 7 second chromoly tube chassis car. but the awd car will live on for awhile.
              • speeding-g60
                • Aug 2008
                • 1186
                this is what i found when i went to fire up the car for race season!
                so my son and i broke down a couple more blocks to use for the new motor
                new bearings and rings, parts cleaned up well, and machining commences. line bore/hone mainline for billet mains, then bore block.
