Coupe 70mm Turbo back exhaust system
  • The Spanish
    • Nov 2003
    • 719
    Just finishing the exhaust system of the car.
    Here in Spain there is no shop that makes custom exhaust (only some racing shops) so I tried to make it as "of the self" as possible.
    Parts used:
    - 70mm Marco's Downpipe (Thanks Marco for your excelent work )
    - HJS Racing cat (100 cells)
    - www.Bn-pipes.de 70mm cat back system without the "y" piece.
    This is what it's in the car now.
    - Left a 70mm SS 304 connection between the CAT and the Bn-pipes system, around 60cmm long. Will be done on monday.
    So here are some crappy phone pics.
    Will have better pics on Monday
    94' RS2 Coupe TT (Twin Torsen )
  • The Spanish
    • Nov 2003
    • 719
    Pic for the center section
    • The Spanish
      • Nov 2003
      • 719
      Pic of the CAT.
      Started the car like that. Great sound
      I was tempted to keep it that way
      The lambda you see there is the old one. Placed for testing because I did not have the correct bolt to block the hole (came with the cat assembly)
      Cheers,
      Rafael
      • WabTheKing
        • May 2004
        • 2567
        what grade are your boxes made out of?are they polished 304? look like you could use em as mirrors!
        • The Spanish
          • Nov 2003
          • 719
          I honestly don't know, Pipe looks the same as Marco downpipe in SS 304 but boxes are really shinny much more than you see on the pics
          I think everything is SS #304
          • porkkis
            • 1994
            You should add something between the DP and cat to make the exhaust flexible.
            • The Spanish
              • Nov 2003
              • 719
              I am building a mount for the CAT to the chasis similar to the OEM setup.
              I am not sure I have space for a flexi pipe.
              Are you saying this for a case where the CAT hits a bump?
              Thanks,
              Rafael
              • porkkis
                • 1994
                It would be recommended in any case to have one. Audi original is quite pitiful. It's only those 3 springs at the first connection.
                By installing a flex part you can avoid cracks at: EM, turbine housing, downpipe. These are expensive parts compared to the flexi so I recommend you to consider this...
                • The Spanish
                  • Nov 2003
                  • 719
                  Thanks I will think about it.
                  I know you are right.
                    That HKS cat in nice and compact !
                    Agree with concerns about flex joints... It would be worthwhile !
                    Can you mention costs of what is involved here ?
                    Another thing to consider is the boost-aware exhaust bypass pipe - like what Soern tested. It would give you a much less restrictive system when on boost than the 70mm pipes you have. I think 70mm is adequate for RS2 spec'd systems on the Coupe as there are clearance issues at 3inches (76mm).
                    Paul
                    • The Spanish
                      • Nov 2003
                      • 719
                      Paul
                      Costs are as follow.
                      Marco's downpipe (ask Marco a.k.a. Pisobiker)
                      HKS CAT around 500€
                      BN-PIPES Cat back system 800€ with a nice discount and without the "y" piece.
                      Expensive but I found no way of making a custom system here.
                      I am going RS2 setup and no more (damm this forum for making me upgrade everything ) this is why I choosed 70mm setup good enough for RS2 setup and without any clearence issues and also I found the Bn-pipes system in this measure.
                      Paul, no idea what you are talking about (Boost-aware... ) please explain.
                      If money were no objet I would go with the following Setup:
                      SuperSprint downpipe and Cat assembly in 70mm (1200 € ) and then the Bn-pipes system. Not because Marco's downpipe is no good. I think is better than the supersprint one, but because their Cat solution is more compact and you won't get any clearence issues (see pic)
                      • The Spanish
                        • Nov 2003
                        • 719
                        Porkkis and Paul: Can I fit the flexy pipe after the CAT?
                        Cheers,
                        Rafael
                        • porkkis
                          • 1994
                          Yes, but it has to allow more movement than when fitted before the cat.
                          • The Spanish
                            • Nov 2003
                            • 719
                            Trying not to sound stupid, but made soome google searches and found nothing about where to buy a flexi pipe. any tips?
                            • porkkis
                              • 1994
                              Try a hydraulic parts selling shop. They probably sell a stainless flexi pipe with braided reinforcement. Probably not super cheap.
