S2 Sedan 1994 Some mods and upgrades.
  • S2Sedanen
    • Mar 2014
    • 20
    • Country: Norway
    No, fits right on like the original one. Only oil cooler that you'll have to connect or do like me, take a tube with banjo's in both end and just connect between the oil "output and input".
    Also the gear shifter "holder" you have to have a 21mm-ich spacer and a longer bolt for one of the holes to tighten it nice.
    • S2Sedanen
      • Mar 2014
      • 20
      • Country: Norway
      Also, the car is now actually in pieces because of im mounting powerflex all over and engine is out for a little service
      • zafra
        • Jun 2013
        • 320
        • Country: Spain
        I thinI think my car may not have either the gearbox, although mine is a 3b must change many more things in aby
        Step 1: setup. <==
        Step 2: potentiation.
        Step 3: enjoy.
        • S2Sedanen
          • Mar 2014
          • 20
          • Country: Norway
          if you got 5 speed gearbox, you have to change more.
          • S2Sedanen
            • Mar 2014
            • 20
            • Country: Norway
            #20
            • S2Sedanen
              • Mar 2014
              • 20
              • Country: Norway
              #21
              • Jaswan
                • Apr 2011
                • 767
                #22
                what are your engine mounts?
                nice car!
                • S2Sedanen
                  • Mar 2014
                  • 20
                  • Country: Norway
                  #23
                  Thanks
                  This ones
                  • Audi80/90ClubEurope
                    • May 2014
                    • 154
                    • Country: Belgium
                    #24
                    That's a great looking car, love it!
                    -1989 Audi Coupé 2017-...
                    -1986 Audi 90 2.2 2014-2017 Daily classic
                    -1993 Audi 80 1.9TDI |recycling OEM parts| 2013-2014
                    -1990 Audi 90 2.3 USA 2012-2013
                    • ralleyquattro
                      • Oct 2007
                      • 536
                      • Home: Poland Current: Canada
                      #25
                      Love S2 limos.. Subscribed!!
                      www.quattro.ca
                      B2: 82 Urq into Sport quattro, 82 4000 2-door, 83 80q 2 Door, 83 Ur-q CDN, 85 Ur-q Euro with 3B, 86 4kq, 59,000km
                      B3/B4: 91 CQ, 93 90q 2.5TDI, 94 80q avant 2.5tdi, 94 S2 Avant
                      • PRY4SNO
                        • 767
                        Nice car! And great progress so far.
                        Looking forward to more updates
                        2013 Touareg TDI /// #farmenwagen
                        • S2Sedanen
                          • Mar 2014
                          • 20
                          • Country: Norway
                          #27
                          Some work is done, just small things left now
                          Engine in
                          Btw, i changed flywheel to 7A and monted spec 3+ clutch
                          Changing bearings
                          To this ones
                          Burning out some bad old ones.
                          In with the new
                          New back brakes. 300mm from S4 B6
                          Quite big difference.
                          Front almost back on
                          Changed carpet from blue to black
                          All the inside list is going to be black like the senter i just painted.
                          • Matts
                            • Oct 2012
                            • 38
                            Nice work and nice car, I like!
                            RS2, S2 limo, UR-Q 20V
                            • Bbmossma
                              • Aug 2014
                              • 120
                              Please post pictures after, I'd like to see how that turned out, especially interior.
                                #30
                                Lovely car.
                                Wish I knew what you do when i was 19. no mind tooling around in uprated S2 saloon.
                                Powder coat your internal door pulls satin/gloss black.
                                9" might be too big for a standard arched B4 shell ?
                                Just curious, what did you change out the FK coilovers, and how do the new ones compare ?
                                Just my own opinion, the exhaust tips are too long making them too obvious. Maybe consider cutting them a bit short to 'lose them out'.
                                You'll enjoy the rear brake upgrade, apart from the improved looks.
                                Mk1 S8 rims maybe ?
                                What's wrong with the oem style Carbon Effect on the dash, compared to the black finish you're using ?
                                Change the oem wood finish on the dash and door cards to carbon ?
                                While the shiny polished metal pipe running into the throttle body might look nice to some, I would have thought that the back plastic one is the better bet as plastic absorbs less heat into itself, particularly as this pipe carries the inter-cooled air from the intercooler just before it goes into the throttle body, not that critical I know, but every little helps.
                                Looking forward to further updates.
                                Enjoy.
