Audi S1.5 [OEM+] - (10-valve turbo B3 Coupé)
Radiator maybe also partially clogged or be full of limescale or maybe one of the previous owners used leakstopper.Leave a comment:
Not really overheating, but it's really pushing it's luck haha
It has always been like this, I remember it running hot even with the old engine. Thinking about it, I should verify that the gauge actually works as intended because I also have an unusually big delay between when the fan should kick on (according to the gauge) and when it actually does, and I've always assumed it was because the thermoswitch position but now I'm thinking it might just be a off gaugeLeave a comment:
There is somehting wrong with your cooling system if it overheats on the highway.Leave a comment:
Hello, is this thing on?
I don't know if anyone who cared about this project is still around, but someone reminded me of this thread today, so I thought I'd update
So after -18's clusterfck of fuel disasters I mentioned that I swapped to a stock WUR and just let her rip.
She felt pretty good so I headed back on the dyno, and after some light tinkering and letting the old gal cool off a bit. She mustered up a whoooping
201whp
361wnm
If we compare that to last years faceplant of 193whp and 315wnm, the extra fuel and the new manifold didn't make us much power, just enough to push me over my 200whp goal (woo!) but instead she's strong as A DAMN MULE I TELL YA with a nice extra ~50nm!
That's 65% more hp and 108% more torque than the NG that first came in this car
And it's 35% more horse and 65% more torque than the stock MC
So with everything running (fairly) smooth, I drove quite a bit this season.
And that showed a problem, the cooling just can't keep up on a warm day on the highway.
3k rpm doing 60mph is pretty rough, so I think I'll replace the small cooling fan I installed with a low-profile SAAB oem one that I got laying about that probably pushes way more air.
But besides that nothing too exciting happened. I've been mostly focusing on my other project (pics about that below!)
I did win 2 new prizes! Top-5 in my class for the third year in a row in a local show, and an award for 'best Audi on scene' at the local racetrack
And because of the way swedish MOT/TÛV works, my car is now old enough to only show up every other year, and she's also tax-free so that's nice!
Next season, besides looking over the cooling I'll probably replace the 'injectors', 'cus I bet most of them have the classic leaking and I don't need anymore fuel-problems... And if I feel really brave I'll maybe change the membrane in the fuelhead
My other project!
She's a weird one! It's a Volvo 360 with a SAAB 2.3t swap, Opel gearbox, Volvo 240/Golf 2 rear suspension, Volvo 240/E39 front suspension and a bunch of custom stuff! It weighs in at 1100kg with full interior and puts down ~300whp and 400nm at a breezy 1bar because of a broken boost controller. She makes a mean burnout
You seem to have the patience of a saint.
Great effort so far, lets hope the results and peace of mind follows!Leave a comment:
That little K24 is a beast!
Speaking of which...
So I finally drug the car out of winter storage and back home. And even better than that, after a lot of searching I found another warmup-regulator!
I cleaned it up a bit and through it on the car as quick as I could. I also cleaned the sot of the plugs and actually gapped them for this season (whoops!)
Right away the car felt way better. The idle was smoother and it was easier to start.
I took it for a testdrive later that night and wooh boy, let me tell ya, it rips. I should have added the extra injectors and just left the regulator alone from the start.
With one extra injector plugged in I get a sliiightly lean AFR and with both of them plugged in I get a little fat.
But both alternatives are far better than the clusterfck that was last season...
So I felt pretty good cruisin around, got home, parked and left.
Came back the day after and was pushing it out and found a big pool of oil under the car... the f?
So... It turns out that for some reason, the oil feed to the turbo decided to come loose and create a small fountain under my hood.
Like everything on this car, it was a bitch to get access to, but I got a new gasket on there and put some proper lockwashers on aswell.
Haven't done anything since that, but it's funny that literally an hour after I get it to run it decides to explode
So yeah, I'm gonna do some more testing and if it feels okey I'm gonna get it back on the dyno to finally get proof of my 200+whp!
But this season sure starts out better than the last!Leave a comment:
Nice to see you're still tinkering with it
The 'upgraded' turbo looks nice indeed.
Nice car!
You should never paint contact surfaces on the wheel hubs. Even dirt on the wheel hubs can cause vibration and warped discs.Leave a comment:
2018 - Round up / 2019 - Prologue
Long time no see my dear Audiots!
So I totally fell off the map last season. I was just so tired of fighting with this thing that by the end I didn't even want anything to do with it...
I spent the whole damn season trying to dial fuel/boost but the god damn thing couldn't keep the same value 2 days in a row.
I could be out one night dialing the fuel as good as it ever's gonna be with CIS. But by the next time I drove it it would be all over the place again????
By the end of the season I've must have tinkerd that pressure-regulator so much it completely broke. Because for some reason I now had way too much fuel all the time.
I could disconnect the extra injector and still run a 8 AFR. It got so much that if I pushed it I'd drench a cylinder and loose spark...
So anyway. New year, new energy. And I reaaallyy just wanna get this done so I can just enjoy driving it without having to oogle that damn wideband the whole time.
My plan of attack this season is to swap the pressure-regulator out for a stock one (just need to find one first), then just see what happens with a stock one + the extra injectors and go from there.
Despite my rear bumper being a constant shade of black from all the smoke I managed to get a few pics, so I'll share those below.
And as always I very much appreciate any and all tips I can get from you really talented guys. So if you think I should check something out, please speak!
2018 - Epilogue 2
When life gives you lemons
And boy have I gotten my share of lemons this season...
So after the radiator failure I drove for a week or 2 while trying to really nail the fuel/boost. And I kid you not, a few hours after I literally said "I'm pretty happy with this, I think this is it"
The car started smelling so much exhaust it made my eyes water. Went home and checked it out, cracked manifold again...
I doubt anyone remembers, but while the engine was out I had the manifold sent away and repaired, but alas it cracked again right through the weld.
And since there's no alternative to buy, I took this as an opportunity to work on my TIG-skills...
The (inside) diameter of the pipes are way bigger than stock (42mm)
No, despite the backassward design of the OEM manifold, it does not have separate channels (except for cyl1/2)
Yes, the wastegate works fine.
Nah it sounds exactly the same...
It's maaaybe 200rpm quicker to spool?
I had more pictures, but they've somehow magically disappeared since last night.
Basically just a shot of the finished piece compered to the old one and the piece mounted on the car.
The whole thing was a major hassle and every single thing that could have gone wrong did (Thanks Murph!)
I would never do this again on a 10valve in a million years and the people who decided that the manifold and intake should be on the same side should be taken out back and shot.
I worked my *** of for a week to get ready for a car show I'd been asked to attend, and with 2 hours to spare, I closed the hood.
And lucky I did! For the second time in a row I won a spot in the "Top10 - Street Class"
So once again, for like the forth time this season, I WILL TRY TO NOT WORK ON IT ANYMORE AND JUST ENJOY IT (SCREW YOU MURPHY)
I'm just gonna go readjust the boost to where it was and hit the dyno again.
Peace out!Leave a comment:
