D2 A8 2.7t - O1E swap, project XFL B5 S4
  • my2000apb
    • Jul 2010
    • 637
    Ok, well I figure it’s about time I started a project thread on this. Project XFL B5S4
    D2 A8 facelift 40V autobox
    Tiptronic gone
    40v gone
    INSERT 2.7T and O1E 6 speed here
    So I’ll keep the back story short and sweet. I picked up this a8 from a friend kinda deal after a third party friend lightly bumper bendered another car. So I got it on the cheap. The weird history of the car has it being totaled via hail damage and then smoothed / re-sprayed at Sewickley Audi outside Pittsburgh. So the paint is ultra -fresh and smooth, needs the bumper and a fender painted, but all in all a great deal and a helluva score! IN the past I had a b5 s4 that was great and all it was just a royal pain to work on. That engine all jammed up in there and no way to fit a wrench anywhere. Ive managed a great deal on a 6speed 2.7t A6 from a good friend. So I’m making myself a XFL B5 S4!!!! Basically a bigger, comfy s4 hahaha. Rocket couch type ride!!
    The 40v is running fine as is the trans!!! both will be up for grabs shortly. I’ve worked on enough audi v8’s to know I don’t want one ahhaha. I will be able to get more power and significantly better fuel mileage with the 2.7t over the 4.2 40v. but even more importantly, there will be soooo much more room around the motor itself. The d2 is much wider than a b5/c5 and is in an obviously longer v8 engine bay. As I am doing a manual swap at the same time, the driveshaft will need extending. It will need extending even if I keep the bellhousing position the same. The 01e trans are sooo much shorter than the TIP equivalents. I am going to most likely, push the motor/bellhousing flange forward about 1 – 1.5”. yes, this is counter to helping the vehicle’s balance. The 2.7t is ~50 lbs. heavier than the alloy 40v’s. That said the 2.7t has a lot more of its weight sunk down low with the iron block and rearward with the turbos hanging off the back. And with it not being nearly as long as a 40v, having more leverage hanging off the front over the axles, I think the weight is pretty much a wash. The motor being pushed forward a tad will give me a lot more room to work around the side and back of the motor, esp. near the turbochargers. And this will still give me a good amount of room to make a nice mandrel bent, non-pancaked-tube, IC>TB hardpipes and eliminate the troublesome factory Y shaped TBB.
    There has been sooo much more development / cracking of the motronic ecu’s since even a few years ago. This will help make this swap significantly easier. Basic ecu mods rundown
    18 psi peak to 15psi taper by redline
    Setup for newer 2.0T pushdown coils, reduced dwell time
    Rear 02 / cat deletes
    All EGTs delete
    PCV/ Emissions Delete
    SAI delete
    Immo delete, A8 is gen3 Immo so it’s a bit complicated
    The fact that ALL these above things don’t need to be there is a HUGE advantage. And will simplify things dramatically.
    Engine Mods
    Custom ME7 tune with lots of deletes
    Full 3" ss304 downpipes with 3.5" wide bellmouths, no cats and 3" midpipes to rear muffler
    Custom Treadstone Intercooler, 25"x6"x3.5" vertical core, 2x inlets, single outlet to>Custom IC>TB alloy hard-pipes
    Integrated Engineering 2.0T push down coil adapter plates
    OEM 2.0T push down coils
    Re-wired, ICM deletes
    Mechanical fan delete, add electric fan to radiator shroud
    External oil cooler
    Drivetrain / Trans Swap basics
    • O1e six speed and c5 a6 2.7t rear diff (short nose like a8, bolts right in)
    • Custom trans mounts (I have these available as well)
    • Lengthened driveshaft (4.5” for mating to 40v, I’m going about 5.5-6” to help center the 2.7t oil pan in subframe and facilitate working on everything.
    • Modified a8 pedal cluster with clutch pedal, cruise control switch etc.
    • Front axles are urS4/6 units (front passenger) and use a 1” spacer that I make for the front/pass a8 location (spacers available)
    • Custom stainless clutch line
    • OEM b5 rs4 clutch kit
    • And I’m sure there’s more but I’ll get to that later.
    AND because we all like pics!!!!!> well I gotta go to work ahaha ill upload them all tonight
    BEAST '90 CQ 24v VRT / O1E / v8 rear, HOLSET SUPER 40 http://www.theprojectpad.com/viewtop...1&t=193#p37887
    DD '86 4kq BLAZE, swapping aba/16vT and O1E http://www.theprojectpad.com/viewtop...1&t=201#p38264
  • PRY4SNO
    • 767
    Hell yes.
    LOL Sewickley Car Store... those sonsofbitches didn't fix my oil pump when I went in for service & trashed my A/C, then called me a thief (!) when I drove back from Montana to get my money back.
    2013 Touareg TDI /// #farmenwagen
      Quite a lost of changes, good luck with the project. Looking forward to following this thread
      • my2000apb
        • Jul 2010
        • 637
        A8 2.7t / O1E Swap thread Updates
        UPDATE!!!! Finally got off the road for the rest of the year and it’s time to make some serious progress on this beast. Yes it will be running and on-location at Carlisle 2015.
        So, I don’t have nearly as many pictures as I want. Since the last update, I’ve been through two computer crashes and lost most of them. That said, those pics aren’t as interesting as the ones that’ll be coming up soon. Everyone loves FabPorn and go-fast parts a lot more anyway.
        Engine and transmission mounts are all finished; I’ll snap some more pics of them and get them uploaded. I have 40v v8/ o1e d2 transmission mounts made and available for sale as well as motor and trans mounts for the 2.7tt/o1e setup in a d2. PM me or email drbeastcar@gmail.com
        Axle spacer installed
        And some tacked together downpipe shots. I built a 2.5”>2.25” downpipe to midpipe setup for a customer’s swap. For my car I built a full 3” downpipe/midpipe setup that stays full 3” to almost the rear muffler. The downpipes then integrate into the factory 40v exhaust. With no cats, resonators, and just the two factory rear mufflers it should sound rather subdued under 3500, and open right up when you get on the throttle. Here they are awaiting transport to final seam welding.
        And for some go-fast fun parts. I had originally intended on running some c5 rs6 intercoolers. Well, there is definitely not room for them. With the aluminum frame-horns being a very different shape, and well a very different engine bay layout. They just will not work. So I started looking into other solutions. There isn’t a ton of options out there for a 6” vertical flow core. So I ended up settling on this one from Treadstone engineering.
        so I bought the core, and some end-tanks separately. I bought longer lower end-tanks with a more gradual taper, so I can cut them down and gain a bit of clearance to fit this behind the D2 front bumper. it will basically be this one, but a little bit shorter vertically.
        The 2.7tt motor actually fits pretty well in the D2 engine bay. The driver’s side turbo oil drain line requires modification as does the drivers side compressor outlet tube, but otherwise fits quite well.
        Ive been spending a lot of time on the chassis plugs adapter harness. Tracing a lot of wires back and figuring out what needs to go where to let it run and keep the dash lights happy. Ill get that finished and summarized in one spot to keep it simple.
        Well back to garage, gotta have her going for Carlisle!!!! Updates will be in much more regularly with my work travel schedule ending for the year. ITS GAME TIME!!!!
